Question about Cisco 7910 IP Phone
How can I clear / reset a Cisco IP Phone 7910
Posted by apaige on
Anonymous
    New Friend:
  • 17 Answers
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Posted on Jan 11, 2011
How do i reset my password for the voice messges on the cisco ip phone 7962
password is a server level not phone, you have to contact your system admin.
Sep 11, 2014 | Cisco 7962G IP Phone
Tip
Cisco IP softphone - one way audio - fix
Using the Cisco IP soft phone via VPN can sometimes cause audio to drop. To fix this:<br /><br />Right click the Cisco IP Phone and select Preferences...<br />Select the Audio tab<br />Click on the Network button<br />In Audio IP Address select Use this address<br />then set it back to Detect Automatically<br />Click OK and OK again.<br /><br />Give it 5-10 seconds and this will auto reset the audio on the IP phone and will correct the issues with one way audio.<br />
on Mar 08, 2011 | Cisco IP Communicator (SWIPCOMME1CH1)
Cisco IP Phone 7945G
Use the professionals rather than "a comment".
Contact Cisco directly here: Cisco Technical Support IP Phone FAQ
Feb 01, 2018 | Cisco 7945G IP Phone
My Cisco IP Phone 7945G keeps rebooting after I did a factory reset. Is there a way to fix this?
According to Cisco, when initiating a factory reset procedure certain information from the IP phone is erased while other information is reset to the factory default value, as shown in the list below:
Information Erased:
  • CTL File (Certificate Trust List)
  • LSC File (Locally Significant Certificate)
  • IP Phone Call History (Calls Received, Placed, Missed etc)
  • Phone application
Information Reset to Default:
  • User configuration settings (ring tone, screen brightness, sound levels etc)
  • Network configuration settings
t is highly advisable to follow the firmware upgrade procedure in a non-working environment to ensure other phones are not affected (in case of an accidental reboot), and to avoid the freshly factory reset ip phones obtaining the working environment's settings.
Please use the link below and follow the instruction http://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-ip-phone-a-ata-firmware-downloads.html
Aug 28, 2012 | Cisco 7945G IP Phone
My cisco ip phone 7960 is stuck in boot up mode after performing the soft reboot. i press 123456789*0#
You can try a couple of things: Unplug the power cable from the phone, hold dows the # key, and then plug the power cable in again. The phone begins its power up cycle. Release the # key after the Speaker button is no longer lit. You should see the following message on the phone: "Reset key sequence detected" Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
Or to perform a full reset: Press **#** to reset the Cisco IP Phone 7960
Mar 15, 2011 | Cisco 7910 IP Phone
How to unlock cisco ip phone 7910
  1. Press **# in order to unlock Network Configuration on the phone.
  2. Press Settings.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) for Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
Mar 03, 2011 | Cisco 7910 IP Phone
Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
May 18, 2008 | Cisco 7910 IP Phone
7910 IP Phone
please check if firewall is ON on your netgear router...
Dec 12, 2007 | Cisco 7910 IP Phone
Cisco ip phoe
Is the phones registered to CallManager or CME?
if CM, then it could be because of partitions and Calling Search Spaces. PTs are placed on the line and are restricted by CSSes. http://cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmsys/a03ptcss.html#wp1020642
If it is CME, then it could be a configuration issue
http://cisco.com/en/US/docs/voice_ip_comm/cucme/roadmap/itsph.htm
Nov 10, 2007 | Cisco 7910 IP Phone
Cisco 7910 IP Phone Logo
3,070 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
