Question about GE 29439GE2 Corded Phone
#29439GE2-C Setting up greeting? - GE 29439GE2 Corded Phone
Can receive and answer calls but greeting announcement is silent.how do I turn on greeting.
Please tell me the model of your phone.However,you can do this with the use of your phone profile i.e from the phone click on it the screw down to the profile then click on it screw to setting or turn setting from there you will be able to get to greeting setting or turn from this step you will be able to activate the turn again .
Good luck.
Thanks for using fixya.
Sep 06, 2011 | Cell Phones
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
My phone is a Nortel Networks phone T7316e I want to change my personal greeting but when i press "pers" it asks me for a greeting number. I do not know what the number is. My extension is 21...
Recording Company Greeting 1 Press FEATURE 9 8 3
The display shows
Log: QUIT RETRY REC
2 Enter 1 0 2 0 0 0 0
3 Press OK
The display shows
Admin MBOX AA OTHR
4 Press AA
The display shows
Auto Atdt Admin GRTG TABLE LINES
5 Press GRTG
The display shows
Greeting Admin GRTG AA
6 Press GRTG
The display shows
Greeting: RETRY OK
7 Enter Greeting number "13" (for holiday recordings
8 Press OK
The display shows
Greeting RETRY PLAY REC
9 Press REC
10 At the sound of the tone record the greeting.
Greeting: "Thank you for calling (your company name)..........."
11 Press OK to end your recording.
The display shows Accept Greeting:
RETRY PLAY OK
NOTE: To listen to the greeting press PLAY, to re-record the greeting press RETRY
12 Press OK to Accept the greeting
To program to play
1 From Step 12 press *
2 Press Table
Auto Atdt Admin GRTG TABLE LINES3 At Grtg table: enter 1
4 Grtg table: Retry OK
5 Press OK
6 Press OK again @ AA menu prompt
7 At Morning: 1 press CHNG to whichever new greeting you recorded
CHNG Morning: 1 PLAY NEXT
8 Continue by pushing next through all times
9 Afternoon:2 CHNG PLAY NEXT
10 You should note which times had which greetings to change back after holiday
11 After you change all the times Morning Afternoon Evening Non-business press Release
This will work for setting a new greeting as well, you can use numbers 1,2,3 etc for the greeting numbers to set them at different times of day in the table.
Feb 24, 2011 | NorStar T7316E Corded Phone
Setting up your voicemail
I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
Nov 15, 2009 | Lands Phones
Does the display on my phone suppose lite when a call is
Yes! but some reasons if the battery remaining is too low, the telephone itself saves the battery for emergency purposes so that's why it wont lite-up.
Sep 30, 2009 | Sport & Outdoor - Others
How do i put a greeting message on my 3g samsung,when mobile is off or busy
You need to call your voice mail, go into personal options, setting, then greetings, and either record your own message or use the standard greeting.
Jul 21, 2009 | Samsung Cell Phones
GE 2-9439 Phone i need the manual to store numbers in one out of the 32 speed dial buttons!
1. Press the button you want to program
2. Press the Store button (red light will illuminate)
3. Enter the phone number
4. Press Store again (red light will flash)
5. Press the button you want to program (again)
Jun 03, 2009 | GE 29439GE2 Corded Phone
Cant change my sanyo 6650 mobiles incoming msg font
here i hope this helps you Display Settings
Changing the Text Greeting
The text greeting can be up to 15 characters and is displayed
on your phone’s screen in standby mode. You may choose to
keep the phone’s default greeting (“Sprint”), or you may enter
your own custom greeting.
To display or change your greeting:
1. Select > Settings > Display > Greeting > Custom.
2. Enter a custom greeting using your keypad and press .
(See “Entering Text”on page 39.) (To erase the existing
greeting one character at a time, press .
To erase the entire greeting, press and hold .)
Changing the BacklightTime Length
The backlight setting lets you select how long the display
screen and keypad remain backlit after any keypress is made.
To change the Main LCD or Sub LCD backlight setting:
1. Select > Settings > Display > Backlight.
2. Select Main LCDor Sub LCD.
3. Select Always On, Dim Only, or a preset length of time.
To change the Keypad backlight setting:
1. Select >Settings>Display>Backlight>Key.
2. Select Always Off or a preset length of time.
Note: Long backlight settings affect the battery’s talk and standby
times.
Note: The Always On setting returns to the previous value the next
time you turn on the phone.
Your Phone’s
Please rate this solution thanks...
Jan 30, 2009 | Sanyo Katana II (SCP-6650) Cellular Phone
GE 29439GE2
Copy directly from the manual: TONE/PULSE Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which type of service you have (pulse or tone), check with your phone company. To program TONE/PULSE for all 3 lines: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press TONE To program TONE/PULSE for each line individually: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press LOWER 5. Press line number (1, 2, or 3)
Jan 11, 2007 | GE 29439GE2 Corded Phone
GE 29439GE2 Corded Phone Logo
128 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
