Since you didn't give much info I'll do my best. Did the error tell you that it couldn't find an operating system? Driver?
Reboot and enter "set up" change the boot order in the BIOS so that your cd/dvd is the first boot device. If you computer isn't destroyed you should get the recovery console then. Try getting into safe mode if possible and doing a system restore, or last known good configuration if you can't restore. If you can boot try those first if not then use the console and try to fix mbr.
MBR stands for Master Boot Record and it's the first sector of your hard drive that basically tells the BIOS where to look for the operating system on your computer.
If, for any reason, the MBR becomes damaged or corrupt, then the operating system will be unable to load. You will normally see error messages like:
Error loading operating system
Missing operating system
Invalid partition table
These messages are definitely not fun, especially if you are not familiar with computers. Most people would automatically assume their computers are dead! However, that's not true. Being in IT myself, these errors are actually preferably to other types of Windows errors. Why?
Well, it's actually fairly easy to fix the Master Boot Record in XP and Vista. All you have to do is load up the Recovery Console and run a simple command. All of your data, applications, settings, etc are still intact on the drive and once the MBR is fixed, the computer will load normally.
So how can you repair your damaged MBR? Here are the steps to follow:
1. First, restart your computer with the Windows XP setup disk in the CD drive.
2. When prompted, boot from the CD drive by pressing any key. If Windows loads automatically, you will first have to enter the BIOS setup and change the order of the boot devices to start with the CD drive.
3. Once the setup loads, you will see the option to press R to repair a Windows installation.
4. Once the Recovery Console loads up, you will have to type in a number that corresponds to your Windows installation. This is normally just 1. Press Enter and then type in the Administrator password.
5. Now at the prompt, type in fixmbr. Your damaged MBR will now be replaced with a new master boot record and your computer should now be able to boot properly. Note that you may also want to run the fixboot command to repair the boot sector with a new one.
Also, make sure you only use these commands on a system with one operating system installed. If you have more than one operating system installed, fixmbr and fixboot could mess up everything.
Fix MBR in Vista
In Vista (I'm assuming you have Vista) the procedure to fix the master boot record is a bit different. You have to start up Vista in the Recovery Environment and then run the bootrec command. Here's how.
1. First, load up the Windows Vista disc in your drive and press any key to boot from the disc.
2. Choose the language, time, currency, etc and click Next. Now click on Repair Your Computer.
3. Choose the operating system to repair and click Next. When the System Recovery Options dialog comes up, choose the Command Prompt.
4. Now type bootrec.exe and press Enter. This will rebuild the boot configuration data and hopefully fix your problem. You can also run the command with switches to fix just the master boot record (/fixmbr), the boot sector (/fixboot), or rebuild the entire BCD (/rebuildbcd).
Hope this helps.
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
What is the make of this computer? and what is the windows that you are trying to install? And why are you reinstalling the windows ?
