Question about Hitachi 61SWX10B 61" Rear Projection Television
How can I fix the convergence on a hitachi 61swx10b? I had a similar Issue with a sony rear projection, and I simply put in a code with the remote and brought up a grid to adjust the convergence. Is there a way to do this with this tv? If it does turn out to be the convergence ICs, where could I get them to replace them myself?
  • Hitachi Master
  • 8,617 Answers
Www.tvrepairworld.com has the convergence repair kit for your model which includes the ICs , Reistors and the CD with instructions.
Posted on Oct 28, 2010
I have arear projection Hitachi big screen that has an unlevel picture. Crooked a bit. How can I manually fix this?
Very common problems for DLP tvs,will get worst as times go by.Tv probally have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B unlevel on the pictures?Crooked pictures have mis colors alignments?Yes.There is no way manually to do an adjustment to fixed for this.Try push the tv remote button that said Magic Focus button.If the tv have data processing never completely done and have a error message and stop.Ur tv 100% have a dead tv convergence board,the tv convergence board must have it parts to be replaced like 2 STK convergence ICS and some or all of it resistors too.Than tv will be able to run the tv remote Magic Focus again to have a 100% data processing with no error message,tv to fixed this problems.The shop will cost u like $300-350 for parts and labors.
Jul 17, 2011 | Hitachi 61SWX10B 61" Rear Projection...
My 61swx10b the colors wont align the picture's bowed top & bottom & there is no sound
Ur tv convergence are dead.U must have a soldering iron and know how to solder to fix this problems.U must replaced 2 STk convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 24, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Hitachi projection t.v. convergence problems
You have a problem with the convergence amps and maybe a few resistor that have changed value,
Mar 19, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Hi,I have a problem with my Hitachi TV, The problem is deflection PCB, part # JT23274, model #43fdx20b, How much is cost to repair?
Hi, i'm a technician in florida.
The cost for me to referb a deflection assy is
289.50 plus tax.
i'll give you a nice tip...sometimes the convergence circuit temps to load the power supply...try to fix the convergence circuit first...then see if that fixed it.
convergence ic# stk392-110...try the stk392-120, they are more reliable...my e-mail [email protected]
Oct 08, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Purple and green color
It sounds like a convergence problem to me. I had the same problem with my set and fixed it myself using a kit I bought from www.TvRepairKits.com. These guys rock!
Aug 19, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Maybe converrgance
If the magic focus doesnt correct the issue you will need to install the Convergence repair kit for your model. You should be able to get one at the following link. Leave them a email or call if you dont see your model as they add new kits everyday or two.
http://www.tvrepairworld.com/
Jul 20, 2009 | Hitachi 61SWX10B 61" Rear Projection...
The 3 color guns seem to be out of alignment and the magic focus button doesn't fix it. Any suggestions?
The Convergence Circuit has failed. Replacing the two Convergence IC's and possibly one or two low ohm value resisters should fix the problem. I do recommend a professional to do the job since there may be adjustments in the factory mode needed after the repair to align it properly.
I hope this helps,
Skyassoc
Jul 18, 2009 | Hitachi 61SWX10B 61" Rear Projection...
My color is off real green you do not see colors like purple and i see blue spots tv hitachi model 61swx10b v1k004865
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Aug 20, 2008 | Philips Magnavox 51MP392H Rear Projection...
Hitachi 61swx10B digital rear project
Yes it certainly sounds like you have the old convergence outpuyt IC's that have gone bad in this TV set. If you have the soldering skills, and know how to work on printed circuit boards, you can repolace both of the STK convergence IC's. If you do not, you can get the complete convergence board at http://www.ptscorp.com, and the Hitachi board number is JT22056. Good Luck
Mar 28, 2007 | Hitachi 61SWX10B 61" Rear Projection...
Hitachi 61SWX10B 61" Rear Projection Television Logo
253 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
