SOURCE: Dynex wireless mouse..DX-WLMSE..Left click does
It is the problem of the Hard ware( Mouse). The contact is not get activated on soft clicks. dismantle the mouse. clean the contact points and put the click button properly might solve the problem. if not it should be replaced.
SOURCE: Mouse Cursor Jumps to the right of the screen
Have you tried going into the control panel - mouse - pointer options - motion speed (slower) and experiment with pointer precision check box? Try it, see what that gets ya.
SOURCE: Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
