SOURCE: Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
Good Luck
Iqbal
SOURCE: unable to save date in m/b bios
make sure your using new cmos battery not yet been use and then set date in your bios and save it after finish.
still doesn't work?
try update your cmos that migth be the problem note! remember always take care of the risk on updating flashing cmos on power interuption never power off if still flashing. or if you update and flush it before it might be a bad flash of your cmos try bring it up to early state or restore your backup cmos firmware or download it to its main manufacture
SOURCE: black screen on boot on biostar mcp6p m2+
That board has a built in video card if I have the right info. If you are using an external video ie plug in card then you need to make sure the onboard video is disabled or that the plug in card is designated as the main video card. Not doing either of those will cause the black screen.
SOURCE: My system cannot continue on its rebooting
reset bios to default settings or factory settings.
Also may try moving the clear bios jumper pin which should be located near the battery.
http://www.biostar-usa.com/app/en-us/mb/content.php?S_ID=387
good luck.
rate this please
