SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
SOURCE: whirlpool super capacity Lsq9549lw0 has trouble spinning on its own.
If the washer does fine thru the agitation cycle (the washing), that means the motor is OK and the coupler is OK. It would not agitate unless both are OK. (and don't listen if anyone tells you the lid switch is bad -- machine would not fill & go thru wash cyle). The spin is another matter. There is a separate tube for spinning the basket. There is a drive block at top of the tube (that sometimes fails) and there is a separate cluch mechanism below, under the tub. Those places is where you should look.
SOURCE: my washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
