Question about Brother IntelliFAX 4100 Laser Fax
I have a Brother Intellifax 4100 I keep getting a change drum soon message and also the copies are getting a little dark does this mean that I need to change my toner cart. or do I have another problem
Posted by glcric on
polytek
    Guru:
  • 453 Answers
Hi
you need to change your cart, and it will go well :)
Posted on Oct 28, 2010
Gray copies
Most likely you do not reset the drum. In this case, a new drum unit serves as the currents in the old, respectively, due to lack of charge is a problem with a gray background. Information on how to reset the imaging drum is open and is the official website of the manufacturer.
5helpful
2answers
New drum replaced,but machine still ask for new drum
Wow. It's obscure and in the manual on page 13-24. Remove and replace the drum leaving the front cover open. Press CLEAR and then 1 to answser the Replace Drum YES question.
5helpful
How do i reset the message change drum soon on
Press Clear.
8 Press 1 and when the LCD shows ACCEPTED,
and then close the front cover.
6helpful
2answers
We have the intellifax 4100. It keeps telling us
Hi Sandy58 this is the fix. all you have to do is: open the front cover (leave it open) and press the clear button then it will ask you NEW DRUM AND YOU ENTER 1 FOR YES and that's it good luck.
any other question please email me,
thank you.
Change drum soon
Instructions are in the box that the new drum comes in.
1helpful
Fax Problem
Once you have changed the drum unit on Brother 4100 you will need to keep the front door open and then press the option button. Your dispay should give show you a drum change option. press 1 to change drum and the machine should show "accepted" after a few seconds. Afterwards, close the door.
2answers
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
16helpful
Change Drum Soon still shows after changing the drum unit
After changing the Drum, open front cover and press "clear" then press "1" to reset.
10helpful
2answers
Brother intellifax 4100
open front cover, press "clear" and 1, that will clear the change drum soon error
2helpful
3answers
Dum problem
1. Open the drum/toner door on the front of the machine.
2. After the beeping stops, press the button on the line of buttons that says Menue Left arrow set richt arrow and clear button.
3. The menu will say replace drum? 1. yes 2. No
Press the number 1 on the number pad and close front door.
Brother IntelliFAX 4100 Laser Fax Logo
Ekse
k24674
