Question about HP Officejet 6310 All-In-One InkJet Printer
HP 6300 is connected via network card to router. Has stopped printing. Will prin diagnostic page using front panel. Shows as connected in HP Officejet software but can nolonger get by directional coms to show ink levels and won't even print a test page from PC.
  • Anonymous Oct 29, 2010
    Link light on router is on. Router status shows IP address for prnter. Can ping from PC to printer. Can initiate network troubleshooter from printer control panel which brings up help inforamtion on PC.
    I have Zonealarm firewall installed, I haven't deliberatley made chenges to this but have now discovered that I can print if I turn the fiewwall off.
Scott Wilhelmi
    New Friend:
  • 72 Answers
- Does the printer have any link lights where the network cable attaches to the back of the printer? You should see green and/or yellow lights on the port to indicate activity.
- Do you know the printers IP address on the network? Does the diagnostic page or test page have this information? With this you could attempt to ping the network from a networked computer to see if the printer is reachable across the network.
Check those out and post back the results.
Posted on Oct 28, 2010
  • HP Master
  • 7,733 Answers
HP photosmart c309 printer continues to not print or will only print the header and stops printing. How do I fix it?
Network troubleshooting
If you are encountering issues using your HP Photosmart over a network, try the following steps in the order listed:
  1. Turn off the router, product, and computer, and then turn them back on in this order: router first, then the product, and finally the computer. Sometimes, cycling the power will recover a network
    communication issue.
  2. For wireless networking issues, run the Wireless Network Test from the product control panel.
    1. Press Setup.
    2. Press the down arrow button until Network is highlighted, and then press OK.
    3. Press the down arrow button until Wireless Network Test is highlighted, and then press OK.
      The Wireless Network Test prints.
    If a problem is detected, the printed test report will include recommendations that might help solve the problem. If you need to change the network settings on your product or have never run the Wireless Setup Wizard, do so now.
    Double-click the HP Solution Center icon, click Settings, click Other Settings, select Network Toolbox, and then select the Wireless Setup Wizard link.
  3. If the previous steps do not solve the problem and you have successfully installed the HP Photosmart Software on your computer, run the Network Diagnostic tool.
NOTE: The diagnostic test might prompt you to connect a USB cable between the product and your computer. Position the product and computer near each other and have a USB cable readily accessible.
To run the Network Diagnostic tool. In the Solution Center, click Settings, click Other Settings, and then click Network
Toolbox. On the Utilities tab, click Run Network Diagnostics.If you are unable to run the Network Diagnostic tool or it does not help solve the problem, check the following sections for additional information:
  1. Make sure that the computer is connected to your network
  2. Make sure that the product is connected to your network
  3. Check to see if the firewall software is blocking communication
  4. Make sure the product is online and ready
  5. Make sure the HP Device Discovery software is running
Sep 09, 2014 | HP Office Equipment & Supplies
8600 printer won't print. Only shows preparing printer on the screen. I have never used this. It's a refurbished machine.
Apparently not well refurbished. HP printers are pretty good about bugging you when Ink is low but I'd also check for gunk on the rollers that may have then sticking. The machine does check them but unlike with the ink you will get no "dirty" machine messages. It will just not ever be ready. Also, make sure you have no network printer software running if the printer is directly plugged it via the USB port. Only run that software if the printer is available via your local network. Simply stop such software and your printer will be available for local use again. I had to plug my HP printer directly into the new PC to install the drivers and have not moved it back to being connected to the router and the network printing software will interfere until I move it back.
Aug 13, 2014 | HP Officejet Pro 8600
Radio on C6180 not working and printer won't print
Try to unninstall the driver then put it again, it should work
Dec 05, 2011 | HP Photosmart C6180 All-In-One InkJet...
I cant plot from AutoCad 2006, using My hp
hmmm.. we only have two computers at my work connected to a router. the designjet has a network card going straight to it. i connect to the router wireless and it reads vista. my boss connects to the design jet thru the router as well with a network card rj cable with xp pro. as for our printer it can be connected via router and does work fine but my boss has it directely connected to his computer and i share it off of his system. then we also have a zerox machine connected via router as well. maybe your router is going out? try a new one or a better one and see if that fixes it. it maybe defected or time for a new one.......
if it was working before then maybe its the router.
Jan 07, 2010 | Autodesk AutoCAD 2006
Can't get the printer to print while connected to a router
Hi! I will be glad to assist you in this issue. This is the link that will help you to fix the issue:
1. Installing the Product Software in Windows XP and Vista for a Wireless Network Connection (Using an Access Point)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01736948&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
2. Installing the Product Software in Windows XP for a Wired (Ethernet) Network Connection
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01708573&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
3. Installing the Product Software in Windows Vista for a Wired (Ethernet) Network Connection
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01710137&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
4. Wireless & Network Issues Link:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=33412&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
Oct 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP P2015dn wirless connection stopped working
There is not wireless netwrok card is HP LJ P2015dn, However as i can understand you r using External Wireless Router or Wireless network or jet-direct card if u r able to work fine on USB than printer printing mechanism is working fine.
If u connect the printer via wired network connection and it keeps on loosing IP address than it may be problem with onboard network card of the printer.
If printer keeps on loosing IP Address than try upgrading the firmware of the printer.
To check the firmware and IP Address of the printer print a configuration page by pressing and holding down green button for 6 to 7 seconds
May 28, 2009 | HP LaserJet P2015dn Printer
Network printing suddenly stopped working
Perhaps you might wanna try checking the IP address of the printer and see if it matches that of the ones that are mapped in each individual computer. There might be many factors in the "strange" events that have occured (PC gremlins, i call it). That should be an initial starting point.
Resetting the router wouldnt help, cause it is the router that issues different dynamic IP addresses (otherwise known as DHPC) to each and eveny node connected to the netwrok as well.
Another important thing to note is HOW these devices are connected to the router. Wirelessly? Wired connection? The fact that you can see the printer via the router means that there is no problem with the router's end, so the problem lies in the intermidiate connection from the computers to the router. Try to work on this angle. Thanks.
-Technomancer
Jun 02, 2008 | ASUS WL-500g Wireless Router (WL500GDLX)
Speedstream 6300 network key
Wireless security is commonly performed by encryption using wep setting a network key. That key is to be shared by both the router and the network card to allow encrypted communications. If appears you have not provided the network key that was configured into wireless router to the wireless adapter card to allow them to exchange encrypted communications. The preferable solution would be to get the active network from the router and provide in to the wireless adapter in the prompt / request you were presented. This will protect you wireless network from access by those you have not shared the key with.
Dec 24, 2007 | Siemens SpeedStream 6300 (33A6300001)...
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
HP Officejet 6310 All-In-One InkJet Printer Logo
180 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
