Canon PIXMA iP90v Printer Logo
Posted on Oct 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the ink cartridge on my canon pixma iP90v printer.
Level 3:
  • Canon Master 7,733 Answers
  • Posted on Oct 28, 2010
Canon Master
Level 3:
Answers
7733
Questions
0
Helped
1864923
Points
21487
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Apr 06, 2009
SOURCE: How do I change the print cartridges on a Canon
visit the cannon site and support center at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=14723#
they will provide you assistance for cannon printer problems. .
don_farr
Don Farrell
  • 1018 Answers
  • Posted on Jun 14, 2009
SOURCE: i changed ink my printer showing wrong cartridge
Make sure you are using factory new Canon ink cartridges.
If you purchased re-filled cartridges or third party cartridges that is most likely your problem.
Don
Anonymous
  • 117 Answers
  • Posted on Jul 06, 2010
SOURCE: i have a canon pixma ip90v and get troubleshooting
this error mostly occurs when the printhead is starting to go bad.
1helpful
"Used ink full" message on Canon Pixma IP90v?
remove the old cartage top side whcih is very small on the top side of toner and put it in new cartridge it will start work. chers
Canon ip90 has a new print head and ink cartridges but does not print, only goes through the motions. What is the problem?
Remove the cartridges and press the end with the ink sponges onto a paper towel. If you see ink on the towel, insert the cartridges and run the cleaning 3-7 times. This will use up some ink, but is the only way to resolve this issue. If you continue to see improvement in the prints, continue to clean until quality is acceptable.
Great Tech Support by TechbuddiesOnline Call 1 855 517 2433
How do you fix the ink absorber when it is full on a canyon pixma ip90v printer?
You can't. Canon recommends that you take the printer in for service.
Canon ip90 waste ink absorber warning
Not all the ink that leaves the ink-cartridge gets jetted onto the paper; some of it is "wasted", and goes into the "absorber".
So, the software inside the Canon printer has mathematically predicted, given the number of pages you have printed, and the number of times that you've turned the printer off, that, statistically-speaking, the "waste ink absorber" is almost full.
Take the printer to a qualified printer technician, for replacement of the absorber, and to "reset" the electronics to "zero pages printed".
How do I change the print cartridges on a Canon Pixma iP90v?
2helpful
Pixma Ip90v waste ink tank full
you need to clean the ink tank...it is usually located at the right most part below the printer cartridges.(cartridge ducking station)
check your user manual on how to disassemble your printer or ask someone to do this for you if you are unfamiliar with printer disaabling.
let us know.
I don't know how to change the ink cartriges in m canon ip90v? Can you help?
just open the front cover and pull towards you the cartridges
4helpful
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
old marine
old marine
ZJ Limited
ZJ Limited
