Cell Phones Logo
Posted on Oct 28, 2010
My nokia c3 keeps freezing when i turn my phone on
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 05, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1637
Points
Same it keeps frezing and restarting at random times and it mainly freezing when i want to go onto my gallery, it also sometimes when i knock my phone on it asks for the time and date which has happened quite alot recently its soo annoying but its happened to 2 of my friends aswell so there must be a fault with the phone
  • sofa111_95 Jun 25, 2011
    my nokia c3 crashes when i go to delete stuff out of my gallery and that
3 Related Answers
Anonymous
  • 66 Answers
  • Posted on Feb 28, 2011
SOURCE: i want to watch movies
Try updating your phone's firmware. Also, check your video file and make sure it isn't too big. Cell phones have limited resources and movies with big resolutions sometimes are too demanding.
Please rate if this answer helped.
Thank you!
Anonymous
  • 1116 Answers
  • Posted on May 15, 2011
SOURCE: My Nokia C3-01 keeps freezing, can't log in to get
This solution should help fix the issue. I advise you use the Nokia PC Suite to backup your phone data prior to doing this reset. Also, you should download and install Nokia Software Updater and use this to update your phones firmware and software in the future.
  1. Enter *#7370# code from the keypad. and press the Dial button.
  2. Type unlock code 12345 press continue.
  3. Restart your phone.
  4. You should check for updates on the phone at this time Enter *#0000# from the keypad and press the dial button
  5. Select "Options" and then select "Check for updates".
Remember to backup your phone before performing these functions.
Anonymous
  • 50 Answers
  • Posted on Sep 26, 2011
SOURCE: My nokia c3 cell phone has a camara malfunction,
For Camera hang ups or frozen if using it, this problem can be fix by firmware restoring, flashing or updating. So try to do a software repair first before proceeding to hardware troubleshooting.
If the camera doesn't turns on or having problem like showing empty or black screen, this is due to problem in hardware.
For instructions to update firmware, please check following link.
Nokia C3 Software/Firmware update
for more help about nokia c3 troubleshooting, click here
I forgot my nokia C3 security code
Unlocking instruction for Nokia C3 ?
The unlocking instruction for Nokia C3 is not very complicated, but you need to remember that you have only 3 tries to enter the codes.
If you enter the codes incorrectly more than 3 times, the code counter might get blocked.
Follow these 5 steps to make your Nokia C3 network free
1. Turn on the phone without any sim card
2. Enter the following sequence (#pw+unlock code+1#) on your NOKIA C3 just like a phone number*
* Characters p, w, + will appear after pressing the *(star) symbol a couple of times
4. Press # at the end to confirm the code
5. Message "SIM restriction OFF" should appear.
Your Nokia C3 is now unlocked !!!
My nokia c3-01's keypad keeps freezing and
If it is the flip top ph I opened mine very carefully and find that after time opening and shuting them the wee computer plug comes aprt from the flip part... it is like a male and female plug I couldn't bleve thats all it was after mths of it playing up then stop'n all together it sat in the draw for nearly a year be4,
I pulled it apart and find the problem its from opening and close'n the ph just open it and plug it careflly back in
May 04, 2013 • Cell Phones
2answers
My nokia C3 keeps turning off
check your battery
try use another battery for checking it
Oct 03, 2012 • Nokia C3-00
6helpful
3answers
Cant turn volum up on nokia c3
A code to turn up the nokia c3 volume
2helpful
Nokia c3 keeps freezin when i try to acsess my memory card nd when i turn it off it switces on but shows a blank screen
HelloFirst of all try to reduce the data which is stored in your memory card.Sometimes this problem occur due to over usage of memory.Secondly,delete some data which is stored in your phone memory.Even the problem still persist insert another memory card and try it.good luck Thanks for visiting fixya.
My nokia c3 cell phone has a camara malfunction, it does not open the camera device on my phone and my phone freezes when trying to process the camera request
3helpful
MY C3 STARTS TO "HANG". WHY IS IT SO?
Good day. Try to erase some files from your phone memory, its always the problem once your phone on a full memory status, do not save a large file to your phone memory. Best way to keep your phone active always remember save the files on your memory card, to avoid phone freeze. Thanks
My Nokia C3-00 has stopped working. whenever I press the keypad, nothing happens, and it freezes when i try to do anything.
I have the same problem did u get urs working again please let me know if there is anything I can do to get it Woking again:)
1helpful
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
