Health & Beauty Logo
Posted on Oct 28, 2010
When I weigh the first time each morning, the weight displayed is almost exatly 4 lbs heavier than subsequent weighs. The lighter subsequent weight readings are very consistent and closely match the reading I get on my older analog scale. Is there a calibration procedure for this scale or some other adjustment that I could perform which would result in more accurate weigh readings?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
164
Points
I am having exactly the same problem! I am using a WW scale. I am hoping the lesser weights are the accurate ones!
3answers
Why does it cost 23 dollars for a package that weighs 17 lbs and a package that weighs only 5 lbs it cost 20 dollars from Pa to Ms
Sometimes, part of the cost of shipping a parcel in the distance of travels.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Riddle solver
Let a be the weight of bag A, b the weight of bag B, and c the weight of bag C.
B weighs 4 times as much as bag A:===> b=4a
A weighs 3 times as much as bag C: ===> a =3 c
Combining the two relations: b=4a=4*(3c)=12 c
c= b/12
If you want the values, use the equation a= b-180
3c=12c-180. Solve for c to obtain c=180 /(12-3)=180/9=20
c=20 g, a=3*20 g=60 g, b=12*c=12*20=240 g
b/c= 240/20 =12
Riddle solver
Let b be the weight of bag B, a the weight of bag A, and c the weight of bag C.
Bag B weighs four times as much as bag A -> b=4a
A weighs three times as much as bag C. --> a=3c
If bag A is 180 grams lighter than bag B--> a=b-180
Solve the system to find a=60 g, b=4*60=240 g, and c=60/3=20 g.
Thus b/c=240/20=12. Bag B is 12 times heavier than bag C or Bag C is 12 times lighter than bag B.
How much do sleeping bags weigh?
The weightof a sleeping bag can vary depending on the type you buy but there's no needfor it to weigh more than 5 lbs. You can buy ultra-light ones that weigh muchless. What are you using it for? If it's for hiking, you need a lighter onethan if it's for family use at home.
I have two Weight Watcher scales, model WW11D. They weigh 4 lbs differently. One is 2 lbs heavy and the other is 2 lbs light relative to the weight registered at a Weight Watchers meeting. Is there a...
You say, that: "I have two Weight Watcher scales, model WW11D."
Can I have three guesses where you purchased them???
Do they come with any sort of warranty?
Their weight is inaccurate as compared to the official scales when you weigh yourself at the Weight Watchers meeting.
Are the people running the Weight Watchers meetings absolutely and totally unable to provide an answer regarding these scales?
Jul 04, 2011 • Vacuums
If there were 8 coins of the same weight kept on 1 side and one coin of different weight but biy mistake the coin of the more weight gets mixed in those coins .we have to find the coin using top pan...
Compare any 3 coins vs and other 3: If the weight is the same, weigh the 2 remaining coins. If one side is heavier remove the lighter 3, and compare 2 of the 3 from the heavier side: If they weigh the same, the one not weighed is the odd coin, if the weight is different, you have found your odd coin on the scale.
Nitrous bottle weight
20 pounds is what it holds, what the bottle weighs depends on what it is made of. A steel bottle and an allumnium one will weigh completly different but still hold the same amount.
Kitchen scales & weights
Hope this helps,plz let me know
JonnieC
Weighing 1
006s1.gifWeigh 1 2 3 on the left and 4 5 6 on the right
If the weights are even go to Weighing 2a
If the left side is lighter go to Weighing 2b
If the right side is lighter go to Weighing 2c
Weighing 2a
006s2a.gifWeigh 7 on the left and 8 on the right
If the left side is lighter then weight 7 is the answer
If the right side is lighter then weight 8 is the answer
Weighing 2b
006s2b.gifWeigh 1 on the left and 2 on the right
If the weights are even then weight 3 is the answer
If the left side is lighter then weight 1 is the answer
If the right side is lighter then weight 2 is the answer
Weighing 2c
006s2c.gifWeigh 4 on the left and 5 on the right
If the weights are even then weight 6 is the answer
If the left side is lighter then weight 4 is the answer
If the right side is lighter then weight 5 is the answer
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
