I assume when you say you disconnect the pressure switch you mean you jump the wiring terminals? You say your vent is clean,but what about your combustion air inlet piping? Is it clear. It is not unusual for a furnace to sit over the summer and have the condensate drain trap dry out. This drain will drain the condensation from the blower and discharge to drain. If there is no water in the trap, it can allow air to flow up through the drain, which will cause a drop in the negative pressure. Try "priming" the trap by pouring enough water down drain hose until water comes out by the drain. If that doesn't work check to be sure motor is going full speed and that there are no creatures that have crawled into your inlet piping over the summer.
Can your draft inducer motor run but not run quick enough to cause the ignitor to light? That's what's happening with my furnace. It has to run quite some time before the ignitor will stay lit long enough to light the burners. I can hear the pressure switch opening and shutting several times and the ignitor turning on and back off before it stays on long enough to light.
Thanks for your help,
