Question about Toshiba HD-A30 HD-DVD Player
SOURCE: toshiba hd dvd remote codes
you can get the users manual online on toshiba's website.
Posted on Mar 16, 2008
One of the best ways to check if an infra-red remote controller is working properly is to look at it using a camera. (a webcam or phone camera will work) The camera will see the infra red radiation as visible light. If the LED lights up (on camera) consistently when buttons are pressed, then it may not be the remote at fault, but rather the receiver in the DVD player. Most of the time though, it IS the remote control at fault, and these are usually easy to get working again.
Couple of things to check are:
1) the battery terminals...
Batteries can leak and corrode the terminals in the battery compartments. Signs of this include rust, green coloured contacts, or a crystalline deposit. If you see any of this then clean the contacts using metal cleaner or some methylated spirit and cue-tips.
2) Broken wires connecting battery terminals to the circuit board...
The soldering in some remotes can be rather poor, and wires can sometimes come loose, especially if a remote has been dropped or bashed about a bit. Unscrew the remote and check everything is connected properly
3) Dirt under the buttons...
This can prevent a button from making contact with the circuit board properly. Unscrew the controller and separate the rubber button pads from the circuit board check for dirt both underneath the pads AND on the metal contacts on the circuit board. Clean as required with methylated spirit and cue-tips and then reassemble.
Hope that helps!
Posted on Jan 08, 2017
