Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Cannot find compatable keyless entry for 139.53647SRT craftsman garage door opener-the one I purchased always erases my remote for my vehichle when I try to program it. What am I doing wrong, seems like its only able to take one program,but I know 2 remotes were once on this one garage door.
Posted by paxtonsmom on
  • deadcandance Jul 16, 2019
    Ok so I am in Canada and I bought this used Craftsman remote keypad that you install on the side of your garage door on the outside of your house. I assumed that as long as the keypad brand was Craftsman, Liftmaster, Chamberlain or Wayne dalton, that any keypad of these brands would work with any of these brands of garage door openers. WRONG!! I spent $40.00 for a used keypad only to find out that it is not compatible. So to avoid you all from making the same mistake...here is what I learned or know now. First off it is very important to try to find out what colour the square plastic learn button on the actual garage door motor was that the remote keypad you are looking to buy , was used with. It is also a good idea to find out what the FCC ID # is on the back of the remote keypad you are looking to buy.Once you have the FCC ID# for example mine was FCC ID# HBW1631. You can type into Google searchbox "FCC ID# Lookup" and that will take you to the FCC's website. If a search box does not automatically pop up, you scroll on the left side of the page and look for "FCC ID Search". A box pops up. The first box is called "Grantee Code (first 3 to 5 characters)...mine was HBW. The second box underneath is called "Product Code (remaining characters of the FCC ID#).......mine was 1631. Hit search and a result should pop up, In that result you see a lot of info but at the far right you will see the lower and upper frequency range of your remote keypad you are either selling or planning to buy. Mine was 315MHz upper and lower range. So that means that my remote keypad will only work with garage door motors that operate on or between a lower and upper range of frequencies that include 315MHz. Now we have to find out what frequency the garage door motor is. If you are buying the remote keypad....as the seller what colour the Learn Button is on the garage door motor. For my remote keypad I bought, it worked with a Green or Purple Learn Button on the motor. So the keypad I bought would not work with my motor with a red learn button. To find out what frequency your garage door motor operates at, you can either call customer service for the brand you own and give them the model number.Or Google the model number to search what frequency the motor operates at. I had a hard time googling it so I just called Chamberlain customer service and they told me my motor is 390MHz. So now I know the frequency range my garage door motor operates within, I can look for used remote keypads, ask the seller what the FCC ID# is, then type it into the FCC ID Search Lookup website to see if the remote keypad frequency falls within the operating frequency range of the garage Door Motor. Hope that helps a bit guys and gals. Kev
Don Maggard
    President:
  • 3,197 Answers
The keypad listed for your model is 53876. If this is the keypad you presently have and the remote no longer works after you program the keypad it could be the remote that is bad. Sounds strange but it is true. Make sure you are programming the keypad like this.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Posted on Oct 28, 2010
I have a Craftsman Keyless entry model 132B2386-6 with flashing lights, wont open. Already put in new battery still doesn't work
Why would my Keyless Entry close but not open the garage ...
www.shopyourway.com > Manage My Life > Questions
Mar 27, 2008 - I have a Craftsman Security+ Keyless Entry, P/N 139.53684 purchased with my ... However, the door will not open, but the keypad flashes as before. ... Check if there is a flashing green light on your wall control in the garage. ... The 2 remotegarage door openers won't open or close the garage door; but the ...
Craftsman garage door opener won't open or close, why ...
Hi, I have a Craftsman 1/2 HP garage door with keyless entry (P/N ... When I click theremote or the wired button, the main lights come on, the motor moves ... Five flashes means that the RPM sensors has most likely stop communicating.
LiftMaster - Support - Videos ' LiftMaster
https://www.liftmaster.com/Customer-Support/Videos
Chamberlain GroupHow to program a wireless keyless entry using your garage door opener's LEARN button. How to ... Why the LED or light on the door control is blinking and my remotecontrol is not working? Why isn't ... Why won't my door fully open? How to ...
Feb 08, 2016 | Building Materials
Why won't it program?
Check batteries. Craftsman owners manual may have troubleshooting procedure. Door opener new? or just started happening? If new there may be a compatibility problem. These things are tricky to keep the Hackers out of your home. So a little persistence and understanding how it works will help.
Jun 08, 2015 | Building Materials
Craftsman 3/4 hp garage door opener
not sure, but see the users manual here:
http://www.manualslib.com/manual/32293/Craftsman-139-5399.html
Aug 14, 2012 | Craftsman 3/4 Hp Garage Door Opener System...
Craftsman Model 139.53684 Keyless entry doesn't work
The remotes and keypad use the receiver which is part of the logic board.'t The button on the wall is hardwired and doesn't use the receiver. You might pull the logic board and check for bad connections on the printed circuit.
Nov 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keylees entry and remote controls do not work at the same time
There are two types of technology with this operator (rolling code and non-rolling code). This operator will except one or the other but not both. It is not uncommon for a rolling code (Security+) remote or keyless to lose the "rolling"part of its technology and become a non-rolling code device so it is not compatable with the rolling code technology. You will need to replace the one remote or keyless that is not like the others.
Nov 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keyless entry pad for garage door opener
THE FREQUENCY OF THE UNITS ARE PROBABLY NOT COMPATABLE THEY CHANGED ABOUT 2 YEARS AGO.
SORRY - I THINK YOU NEED A NEW KEYPAD TO GO WITH THE NEW OPENER.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
253 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
