Question about HP Photosmart 8450 InkJet Printer
I have the photo printer for 4 years, just installed it with original ink cartridges, the printer prints regular text just fine, but in trying to print photos, the photos come out very red with no definition of color. HELP
Posted by apache41 on
  • HP Master
  • 7,733 Answers
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: I have the photo printer for 4 years, just - s.gif HPPDU.exe [1/1, 1.54M] System requirements: No I have the photo printer for 4 years, just - s.gifional prerequisites Released: I have the photo printer for 4 years, just - s.gif-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), MicroI have the photo printer for 4 years, just - s.gifWindows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Posted on Oct 28, 2010
My printer is printing blank pages
I used to have one of these printers.
1. Check the ink levels.
2. Try printing on DVD.
The C309 has a black photo cartridge.
Text prints from the regular black cartridge and pictures print from the photo black cartridge.
THe best way to tell if by checking first the ink levels and replace cartridge if necessary.
One thing you can do to check if the printer is printing is by adjusting on the Printer Setttings and printing on one color.
To do this you need to choose the color from a circular palette .
Another way is to use Word or any other processor and change the font color to blue and print it.
Hope it helps.
Feb 05, 2011 | HP Photosmart Premium C309A All-In-One...
Poor color printing
It means that the printer is not spraying properly all colors.
If the bar are regular, that means that the printhead is blocking the spry at regular times intervals.
Sometimes this problems is related to the printhead.
You find out if it is a faulty printhead by removing it, leaving in in isopropyl alcohol overnight or replacing it.
If printhead is fine then it is a problem with the control board.
Sep 14, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Installed HP Deskjet D4160 on my Windows XP system. Worked well a year ago. Lost drivers when computer was cleaned. Reinstalled the drivers and it will print colors and graphics but will not print black...
Doe's it have a color and a black ink cartridge? Got unplug the cartridges and plug them back in. Go to the folder where the printer is installed in program files. Find printer toolbox program and run it. It should tell you ink levels.
May 24, 2010 | HP Deskjet D4160 InkJet Photo Printer
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The dont know how to switch the ink cartages
The large black ink cartridge is used for printing text and other general black printing. The small black cartridge is used when printing graphics and other fine details. Each cartridge feeds to a different part of the print head, which is used for different purposes.
May 27, 2009 | Canon PIXMA iP3600 Photo Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
Printer will not print black ink
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
Won't print text
This is a photo printer. My regular printer will not print photos and if I am correct photo printers will not print regular documents. They are made for separate document types (ex. doc and jpeg). This is so the corporate winners can steal more money from the consumer. I am sure there are printers out there that do both, but your printer is specifically a photo printer. Ask a tech at Best Buy or Circuit City. Let me know what they say.
Cynthia Charczenko
Jan 15, 2008 | Lexmark P707 Photo Jetprinter InkJet
Chewbacca08's solution gave me an idea. I set the print setting to photos paper (even though I was trying to print on plain paper) and IT WORKED. It's worth a shot before you trash a perfectly good printer.
Jun 25, 2007 | Canon i850 InkJet Photo Printer
HP Photosmart 8450 InkJet Printer Logo
333 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
