Question about Stanley Hand Tools
How do i change the blade on the stanley 20-115 hacksaw?
Posted by brett_good88 on
Anonymous
    Scholar:
  • 127 Answers
The 20-115 uses a quick release lever at the front of the saw. Opening the level by hand with a forward motion will unlock the blade tension allowing you to replace the blade. Pull the level closed to restore tension to the new blade.
Posted on Dec 27, 2010
Tip
Choosing the right hacksaw for your job
For every project that you want to work on, there will be a different set of tools that you will need to use. The hacksaw has different types of blades and frames that can be switched out for the different projects that you are working on.
There are three main kinds of blades that the hacksaw can use and each one has different benefits. The teeth on the hacksaw blade will range between 14 and 32 teeth per inch. The thicker the blade the fewer teeth there will be per inch on the blade. The types are regular, raker and wavy. Regular blades are good for soft metals that don't have a lot of metal and the teeth will be closed together touching and alternating left and right. The raker blade has teeth placed in sets of threes and are best used fro cutting through thick metals. The last kind of blade is called a wavy blade, on these ones the teeth are in a wave pattern that are great for making smooth cuts in hard thin metals.
When it comes to hacksaw frame types there are two types to look at the fixed frame and the adjustable frame. Fixed frames are only able to hold a blade of a single sized length of blade. The adjustable frame can hold different length blades typically between 10 and 12 inches. The blades that you will buy for a hacksaw will have holes on either end of the blade. These holes are used to attach and dettach the blades from the frame.
Whatever the blade that you are using make sure that when you are sawing through metal make sure that you go slow because rubbing metal on metal will generate a lot of heat and can spark. You can also ruin the blade on your if you are sawing too quickly.
on Feb 02, 2014 | Saws
How to change stanley 99E blade
Hello, Go to this youtube website too see video on changing the blade.
Jan 01, 2014 | Stanley Bostitch 10150 Straight Handle...
Remove broken key from egnition
Hi
Use needle-nose pliers to pull the broken key out, if there is enough of it sticking out of the ignition to grab. Put a little melted wax, Museum Putty or Super Glue on the pliers before you grab the key.
Make sure that the ignition is in the "neutral" position so that the tumblers are not gripping the key. If it is in the locked position, insert a thin hacksaw blade--with the teeth facing up--next to the broken key, and turn the ignition to the "neutral" position.
Pull gently up on the hacksaw blade. If you are lucky, the teeth will grab the key and slide it out. Try this with the hacksaw blade behind the key, and again on top of the key. Most keys have a groove on them that the hacksaw blade can grab, so wiggle and twist the hacksaw blade around and see if you can feel it catch the key.
Try using the hacksaw blade and the pliers together--pushing with the blade and pulling with the pliers.
Cut or break a six- to eight-inch piece off of a wire coat hanger and use your pliers to fashion a small hook at the end. Slide this into the ignition behind the key and try to grab it. If that doesn't work, insert the wire in front of the key and try again.
Spray a little cooking spray or WD-40 into the ignition and try again with the hacksaw blade. Remember to try both in front of and behind the key, and to wiggle the blade. Do not spray the lubricant before trying the pliers or wire, because now your key is not only stuck, it is slippery.
Call a locksmith if the above steps do not work. Do it before you get too frustrated, because it is much cheaper to replace a key than it is to replace a key and a shattered ignition.
Also check this useful link:-
http://www.diylife.com/2010/06/24/the-daily-fix-remove-a-broken-key-from-a-lock/
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 23, 2012 | 2002 Kia Spectra
I bought a new balde for hax saw and somehow i get the new balde inn, everytime i tried to tightenning it always lose.
it there is not enough adjustment left to tighten the blade the frame is bent or you have the wrong blade.
Sep 24, 2011 | Stanley Composite Hacksaw
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
STANLEY QUICK POINT BLADES...CAN'T FIGURE OUT HOW TO CHANGE.
There is a SLOT in the end of the knife. Simply insert the strip of new blages in to the slot and you are ready to go.
Good luck. :)
Apr 25, 2009 | Stanley Hand Tools
Hand Tools Logo
519 people viewed this question
Top Stanley Hand Tools Experts
Marvin
Marvin
efs_perpends
efs_perpends
Bill Boyd
Are you a Stanley Hand Tool Expert? Answer questions, earn points and help others
