Question about Samsung HL-S5087W DLP TV
Stand by/temp, timer and lamp lights flashing. when trying to turn on the lamp light flashes and shuts back off after about a minute.
Posted by power_str951 on
ladywinn
  • Samsung Master
  • 5,138 Answers
Replace the Lamp .Mats has them for $99.00 1-800-628-1118
Samsung parts.com 1-800-627-4368
Posted on Oct 28, 2010
Okay, so last night my Hitachi 55vs69a starting shutting itself off. I could turn it back on after a few minutes and within an hour or less it would shut off again. This morning it will not turn on at all....
If you bought a cheap non Hitachi lamp that could be bad and look fine.
I would remove the lamp and look at it and reinstall it making sure it is in properly----what was wrong with the old lamp? Did it still work at all?
Dec 08, 2012 | Televison & Video
Samsung DLP 72" HL72A650C1F keeps turning off amd on
Did you buy the original lamp?
If the problem is related to the lamp door switch, you will get a different error instead of lamp LED.
Do you hear the color wheel spinning?
Again, if it's a color wheel problem the error will be different!
My good guess is the lamp but, it could be the ballast or both.
Best of luck
www.aaatvservice.com
May 08, 2012 | Samsung SELECT HL72A650C1F Rear Projection...
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
Mar 12, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Tv turns on for about 1 minute then turns off by itself
could be the lamp. It is consumer replacable.
Aug 10, 2009 | Televison & Video
Samsung HL-S5087W DLP TV Logo
756 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
