Question about HP DeskJet F380 All-In-One Printer
The ink light keeps blinking but the cartridge is full. Also what does the E above the plain/photo paper panel means.
Posted by mally83002 on
okeoma onyedikachi
  • 425 Answers
Hi, you can use this link to know possible codes for HP DeskJet F380 All-In-One Printer.
printertechs.com/tech/error-codes/error-codes-A-E.php
hope it helped.
Thanks for using fixya...
Posted on Oct 27, 2010
  • t166 Nov 01, 2010
    i had tha problem and i bought a new ink
    the ink light kept blinking and i cleand the golden side in the back of the ink box and in the place where u put the ink in
    it didnt work but a massege came in the screan and it was showing that the ink i have is full and new.
    i clicked ok for prenting a new testing paper and nuthing hppend
    but in 10 mins after doing that the printer started working and the paper came out :)
    the printer didnt work for about a year and i had the problem be4
    and 2day i just fixed it :)
Nov 16, 2010 | HP DeskJet F380 All-In-One Printer
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
All printer inks are empty on monitor but i have
You did not indicate whether the printer goes through the motions of printing but delivers a blank paper, or wheter it just stands still and doesn't move at all.
So I have to give you solutions to the two scenarios.
1st Scenario
If printer goes through the motions of printing but delivers a blank paper. The cartridge nuzzles are likely blocked. Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a place/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
2nd Scenario
If printer does mot go through the motions of printing but just stand still. This could be as a result of either of these scenarios. Usually indicator lights blink continuously in this case.
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Dec 06, 2009 | Epson Stylus Photo R200 InkJet Printer
Display flashes e2 alarm light blinking won't print or copy
E2 mean reload the paper correctly and press Black or Color key from panel board.
Dec 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
Red light is plinking
this mean that your printer waste pad is full and your printer needs to be reset go to this website http://www.ssclg.com/epsone.shtml
this will reset your printer
plz rate me
Mar 23, 2009 | Epson Stylus Photo R300 InkJet Printer
Printer will not print
Which of the two red lights is on? If it's the red paper light, it simply thinks it's out of paper. Make sure your stack of paper is properly seated in the Automatic Sheet Feeder. If it is the red ink light, it means that during a print task (printing, head cleaning, ink charging), an empty cartridge was detected. Go through the cartridge replacement procedure as described in your User Manual. If you don't have one, see:
http://files.support.epson.com/htmldocs/sc88__/sc88__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
"Replacing an Ink Cartridge.
If this information doesn't answer your question, please post a new comment with more information on what you want.
If this information was a help, please rate it.
Jan 25, 2009 | Epson Stylus C88 InkJet Photo Printer
Canon i9950 prints green on photo paper
I had the same problem. Having checked other websites I came across the following which narrowed down the problem to the Photo Cyan / Photo Magenta ink tanks, and replacing the Photo Magenta one (although it was not empty) has successfully resolved the problem. Eveidently ink from the original one was not flowing and so caused the syan cast. (I experimented by subsequently removing the Cyan one which produced prints with Magenta cast)
TEXT OF POST I FOUND:-
That post is labeled "Cannon (sic) S9000 Print Head" and concerns a greenish hue error in all print quality levels OTHER THAN plain paper. In other words, all output designated as Photo Paper Pro, Glossy, High Resolution Paper, etc., results in output with enormous and unacceptable levels of green hue. All output designated as "Plain Paper" whether the output actually is on plain paper or photo paper pro, turns out well.
This problem is not unique to the S9000, as I experienced it identically with the S820 and predictably can occur in any printer with the six cartridge print head.
It is a frustrating problem because you know that the printer is physically capable of printing WITHOUT the hue (as it proves to you each time you choose a "plain paper" paper setting.)
Troubleshooting by reinstalling and updating the printer drivers, and uninstalling/reinstalling the ZoomBrowser EX, replacing the ink cartridges, and deep cleaning are all blind alleys.
A call to Canon support solved the problem for me with this simple and important revelation:
The Plain Paper setting is unique in its use of only 4 of the 6 cartridges. In the Plain Paper setting, only the black, cyan, magenta and yellow cartridges are utilized. The Photo Magenta and Photo Cyan are not utilized. In all higher resolution settings, i.e., in all other settings, all 6 cartridges are utilized.
It follows that if one's problem disappears when not using these two Photo cartridges (i.e., when printing at the Plain Paper setting), then the problem lies with these cartridges.
(In my case, I'd loaded a plain "Cyan" cartridge in the "Photo Cyan" slot during earlier trouble shooting and had forgotten to replace it with the proper Photo Cyan cartridge.)
Problems with magenta hues would admit of the same solution.
Hope that helps anyone else out there tearing out their hair trying to troubleshoot this. "
Dec 10, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
PIXMA MP500
The number 5 is a Pigment text black while the number 8 is a dye photo black. The text black is for black text mainly and the photo black is for use when printing photos. Since the text black is always running out it means you are printing a lot of documents in plain paper mode.
I recommend using QUALITY refill ink like Hobbicolors which is sold on eBay and will save you a bundle of money. The MP830 is a 5 ink printer so you need the 5 ink kit like the IP4300.
Dec 20, 2007 | Canon Pixma MP500 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
882 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
