Samsung HCL4715W 47" Rear Projection Television Logo
Anonymous Posted on Oct 27, 2010
The screen went out on our rear projection Samsung TV. My husband had unplugged the TV and waited about 5 minutes. Plugged the TV back in, the screen worked again for about 5 minutes and went out again. Tried unplugging and waiting several more times but either we would receive a line through the screen or a blank screen; no picture.
  • 3 more comments
  • Anonymous Oct 27, 2010
    No there is no sound. My husband may think there's not power going to the TV. We have the TV set up on a surge protector.
    no there is no sound or picture...
    it's blinking and 3 blinks in between each pause
    Where do I purchase a Horizontal Output Transistor?
    Ok, will not be able to repair myself. Can you tell me the estimated cost to have a repair service come out and repair?
Anonymous
Level 3:
  • Master 4,889 Answers
  • Posted on Oct 27, 2010
Anonymous
Master
Level 3:
Answers
4889
Questions
8
Helped
1512247
Points
14106
When you say blank screen and no picture, does that mean you still have sound?
  • 3 more comments
    Ok. What is the status of the LED at the front? If its blinking, then count the number of blinks in between each pause and let me know.
    Ok. That error code is not listed in the service manual but based on your description of the problem, it sounds likeyou have a bad HOT. By running the tv despite of the fault , you have probably damaged a few other components that are causing the HV to drop. I have a list of possible sources of failure that can cause this problem, but as I have said before these are part of the HV circuit. It may not be such a good idea to do it yourself if you have not worked on HV electronics before.
    By HOT I mean Horizontal Output Transistor. Sorry got used to the lingo!
    You can purchase it online. But first you should locate the component itself and get me number written on it EX: Q401 . If you can get me this then I can tell you where to buy it. Note that replacing this component requires soldering skills.
    Expect a charge of about 100-150$
    You can use our repair directory to search for techs in your area.
    http://www.fixya.com/Repair
Samsung TV Issue- Screen went black while watching (image disappeared from left to right)
Hi Ralph, you have a bad tcon board or a bad panel, this model had a lot of both panel and tcon issue, finding a board may be difficult and expensive.
All of a sudden the screen went light blue. The
Hmmmm! I would have to say you have a problem with the signal board. I have not repaired this brand or model. This would be the first thing to investigate. It is the board that contains all your antenna and rca jacks. Good Luck and visit your TV tech with this info!
I have a Mitsubishi diamond WD-62725 the lamp light was on so i ordered a new replacement for it I installed the new lamp and the picture looks brighter than ever remember seeing it but the lamp light is...
we have the same brand tv but the 65" model. had a 4 year warranty just in case the lamps went out. the lamp went out and we called conn's to come out and fix the tv. the repairman replaced the lamp, and then he said to unplug the tv from the wall or the strip it is plugged into and wait 5 minutes and then plug it back in. he left and said to call him back if that did not work. did what he said and it fixed the problem. try unplugging the tv for 5 minutes and plug it back in and see if that might take care of your problem.
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Tv picture keeps turning off
several things, cooling fan out, bulb going out, lamp ballast or the power supply board could be failing. call 1-800-samsung for nearest service center.
Samsung DLP TV HL-R5067W green vertical bars on screen no picture
This is going to be a bad digital board. It is a very common issue with the HLR series.
TV Picture problems
My samsung did the same thing right before my color wheel went out. Can't be sure but that is what was wrong with mine. hope this helps.
Sound went out
Please help ! I moved my Samsung hcn4226w and reconnected. The picture is fine but, no sound now and cannot use all functions on the remote. Any suggestions would be great. Thanks.
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
