Question about KitchenAid KESC300 Electric Kitchen Range
Gives codes F-2 &F3 what is the problem [email protected]
Posted by jachin2145 on
okeoma onyedikachi
  • 425 Answers
Hi, Error Code F2
An F2 error code indicates a failed connection with the keypad. Ensure that the connection between the keypad and control board is tight, and press the "Cancel" key. Wait one minute to see if the error code returns. If it does, the keypad is defective and needs replacing.
Error Code F3
F3 error codes are triggered by problems with the oven temperature sensor. You cannot tell whether the sensor has shorted out or has simply failed to generate a reading if your Whirlpool range only displays two-digit codes. On a Whirlpool range with four-digit error codes, the F3-E0 code represents a failed temperature sensor and F3-E1 represents a short in the sensor. Regardless of which code is displayed, replacing the temperature sensor is the only way to correct the problem.
Hope that helps.
Thanks for using fixya...
Posted on Oct 27, 2010
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Samsung dishwasher dms500trw. what does error code f3 mean. i just replaced the hose after e2 code now 2 weeks later i have f3 code?
Samsung DMS500TRW - ProductReview.com.au
www.productreview.com.au > ... > Dishwashers > Freestanding > Samsung
Rating: 2.4 - ‎49 votes
2.4 out of 5 stars for Samsung DMS500TRW in Freestanding Dishwashers (page 2). ... The machine gives an E2 error and will not pump water out. I have to manually cup it out. ... F3 Error. 1 out of 5, reviewed on Sep 30, 2013. Purchased dishwasher in Jan 2012. First broke ... F3 what dose this code mean? Dell asked on ...
Nov 26, 2015 | Dishwashers
Comcast code
Good code. What about..?
Good luck
mai
May 15, 2017 | Microsoft Computers & Internet
Hi you you there money money money???????????? got none
I just heard back from orange. Here is the body of the response.
Hi Vito,
Thanks for your inquiry, but I'm not sure what amp is to which you are referring. To my knowledge Orange has never produced a "Sundown Rover 15 Watt." If it is a vintage amp, we wouldn't have a schematic for it regardless unfortunately.
Perhaps you could give me a little more info on it or snap a picture and send it in an email?
Cheers,
Alex
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
[email protected]
[email protected]
www.prolinemusic.com
Jul 15, 2011 | Orange Amps Orange Sundown Rover 15 Watt...
Remote control code for a Comcast remote, Hisense LHDN32V tv, code in maual 10748 doesnt work.
here is a site that gives you all of the remote codes for your comcast remote. Scroll down to comcast and select the correct comcast model. It will show you all of the codes for everything
Good luck
http://remotes.com/store/codes_original.html
May 03, 2011 | Televison & Video
I keep getting error message.....Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB6.6; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR...
Does this only happen when you try to access a page from 'www.comcast.net' ?
Within Internet Explorer, click Tools.
Click Internet Options.
Under the "Browsing History" section, click Delete,
to remove any "temporary" files.
Then, try again to access COMCAST's web-site.
Nov 12, 2010 | Microsoft Internet Explorer 8
Comcast remote control code
Hi, the Toshiba codes given at comcast.net web site are: 10156, 11935, 10832, 10036, 10149, 11343, 11959, 10060, 11265, 11369, 10003, 10154, 10250, 10781, 10178, 10702, 11314. One of these should give you control your TV. If you were to still have a problem try their web site direct and contact their customer service, you might need another remote.
Jul 28, 2010 | Toshiba Televison & Video
The manual does not list the actual remote control code
 It will be one of these:
11866, 10054, 10030, 10706, 11990, 11963, 11913, 11904, 11525, 11365, 11198, 10802, 10230, 10187, 10186, 10179
As found in the online manual at::
http://www.comcast.com/DIGITALNOW/Contents/DTARemoteGuide.pdf
I hope this helps
Sep 08, 2009 | Philips Televison & Video
Iphone mail account set up W/ Comcast
SSL is the secure socket layer. SSL provides encrypted flow of traffic for your email. If your provider does not have SSL, you will need to connect without this additional level of security.
Jan 28, 2008 | Apple iPhone Smartphone
KitchenAid KESC300 Electric Kitchen Range Logo
1,073 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
wp4eld1
Level 1 Expert
gbob59
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
