Question about Canon Digital Rebel / EOS-300D Body only Digital Camera
Error 5- it says bulit in flash not working - how to clear this problem
IT IS NOT WORKING.sAYS ALL APPS HAVE STOPPED
Remove your battery for a few minutes . Then replace.
Mar 03, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
My bulit in falsh pops up but wont fire
It can be that the line to the flash unit is broken or damaged. Since the flash pops up the trigger from the processor is correct and the possibility that the connection has snapped is high .
If not the flash unit - inverter side or the flash tube or the capacitor is faulty.
Jan 22, 2011 | Cameras
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
F5 Error flashing
Hello sir; The F-5 means the exposure lamp bad, replace it, will take care your problem.
Apr 24, 2009 | Sharp AL-1642CS Copier
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
ERROR SIGNAL CODE 5 FLASHES
Error also refers to the EEPROM for the printhead. I would reset the EEPROM and see if that helps.
Printer servcie manual here and it will show you how to do it:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
Hope that helps
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Configuration error code purple
1. Load the system recovery disk into CD-ROM
2. Press F10 repeatedly at boot screen to load the Recovery Menu
3. Press R for the recover console
4. Select "Advanced Options"
5. Press Alt + D to bring up the command prompt
6. type "cd h:\" to enter the root directory
7. type "dir /w" to view the directory in wide view
8. open the master.log file (or something along those lines), this should bring up a prompt asking you what program to open it with, you should only be able to select notepad.
9. open the file with notepad and when it appears select the File>Open
10. in the file name box type in "C:\hp\bin\configcheck\run.py"
11. once the file opens clear the contents and select save as then save the file as run.p_
12. close the notepad program
13. delete the original file by typing "del C:\hp\bin\configcheck\run.py"
14. reboot system
After a reboot the windows screen might flash a few times and take a little longer to load, be patient and you should be able to continue with the windows set-up without that damned code purple error message.
Oct 02, 2008 | Computers & Internet
Canon Digital Rebel / EOS-300D Body only Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
