Lands Phones Logo
Posted on Oct 27, 2010
My nokia set is x 3. i have updated my software to the latest one. today i closed my phone and after a while i started it but it is not starting. it only starts up to nokia name appears in the display but after that it blinks three times and then shut down. i have opened my battery and memory card as well as sim card and then tried to restart it without simcard and memory card. but same things happens again and again. i have also tried to charge the phone same thing happens. what should i do.
3helpful
Software update
You can:
1. type *#0000# to check the current software installed in your phone.2. select options then select check for updates3. if there are available new updates just select start update.4. follow the process for software update.
You can also:1. go to settings2. select icon for "software update"3. it will provide you access doing the update to the latest version available for you phone4. start update5. follow instructions for update
*you can also update via pc suite from your pc, you need to download the latest pc suite from nokia.com/softwareupdate*you can go to www.nokia.com/software update then select your phone model and the just follow the instructions
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
3helpful
My nokia c3-00 has lost its calculator as well as the communities and mail thingy... This problem started to happen when I tried to reset factory settings... How can I bring those back? Do I have to...
the best idea is download the nokia software updater and update your phones software with the latest update so you can easily get those all.before update software bavkup all your contents
2answers
3110c says phone memory full with only 575 contacts. I used to have 1500 contacts. Upgraded the firmware to latest version. How can I get the unit to accept the 2000 contacts it is originally designed to...
If your able to switch on your phone then try this
To reset your Nokia phone please follow this.
Press 3370#
It would reset the phone to factory settings.
The default code is 12345
or
If your phone is not starting please press these buttons simultaneously.
onoff + + 3
If still the problem persist scan your phone for any virus.Your phone is affected by virus.If stilll problem persist you have to flash your phone.
My phone is stuck on "Nokia" that comes on starting up.
It may be due to software problem or due to a virus
there r 2 solutions for this problem....
1. Update ur mobile software using the latest Nokia Software Updater present in Nokia PC Suit (update).
This is ur own risk. U should have a stable internet connection and the full charging of ur mobile battery as if ur mobile update is interrupted, ur phone no longer works. So Be Careful.
2. Simple go to ur nearest nokia care center and give Rs.300/- if u dont have warrent and get ur mobile updated. If u have warrenty, it is free .
CAUTION: BEFORE UPDATING OR TAKING TO THE NOKIA CARE, PLEASE BACK UP UR DATA PRESENT IN THE PHONE MEMORY. BECAUSE ONCE UPDATE STARTED, UR DATA WILL BE LOST PERMINENTLY.....
ENJOY UPDATE!!!
Nov 12, 2010 • Nokia 7210
1helpful
2answers
I want to update it software version via USB cable
Nokia 6300 firmware update
Subject: how to update firmware for Nokia 6300 to the latest official version
1. You need download and install NSU - Nokia Software Updater (http://europe.nokia.com/support/download-software/device-software-update/download#) and run it to ensure that all is ok! (don't forget to switch on and connect Nokia 6300 via USB with PC)
2. You need to download and install NSS (Nemesis Service Suite) (http://www.b-phreaks.co.uk/index.php?main_page=page_2), the latest version of NSS was 1.0.38.15 (select "Virtual USB Device" mode)
3. Close NSU if it's not closed and load NSS then click icon "Scan for new device"
4. Click icon "Phone Info" and button "Scan" inside it
5. If all is ok you'll see some lines with Phone Version, Phone IMEI and so on
6. Click button "Read" and remember your "Product Code"
7. If your want to clean your phone go to tab "Tools" and switch to subtab "Factory Setting", choose option "Full Factory" then press button "Reset" (NOTE!!! all personal data and settings will be cleared!)
8. Return to tab "Phone info" and type in the field "Product Code" the following code 0537621 (or any code from (http://www.expansys-usa.com/ft.aspx?k=96957)) for version 7.21, or code 0557624 (or any code from (http://www.a2phone.com/6300-rm-217-dp20-900-sw-0730exe)) for version 7.30, select option "Enable" then press button "Write"
9. Close NSS, run NSU
10. Now NSU should update firmware to version 7.21/7.30 (or any latter build) (http://europe.nokia.com/support/download-software/device-software-update/can-i-update)
11. Repeat stages 3 - 5
12. Type in the field "Product Code" the code that you remembered before, select option "Enable" then press button "Write"
13. Close NSS
14. Use you clean phone with new firmware!
2helpful
I usung nokia 6300 and iam dowloding opera .opera not work my nokia 6300 and how to up grade my nokia 6300
hi may be the opera you are downloading is not suitable for your handset its better for you to not download opera
I bought Nokia 6300b RM-222 with firmware version 4.71, but now the latest firmware is 7.30 (or any latter build). But Nokia Software Updater (link) told me that I already had latest firmware and refused to update my phone. Below I described the steps to upgrade Nokia 6300b RM-222 from version 4.71 (or any other version) to version 7.21/7.30 (or any latter build).
13. Close NSS
17helpful
2answers
I want to latest update for my nokia 7610 phone software
Dear u can find the latest firmware update available for ur phone at the nokia.com/softwareupdate.You can update if any update is available via NOKIA SOFTWARE UPDATER.
Dec 07, 2009 • Nokia 7610
Nokia 5800 web doesnt work
You should check if you have upgraded your Nokia Phone to latest available firmware, this should fix the problem, you can check the current handset firmware in the handset menu -> settings -> Phone -> Phone mgmt ->Device Updates
Select option menu and click on check updates
You can also install the latest firmware through Nokia PC software on your computer, remember to take a backup of your stuff
I had faced a similar problem with my browser, facebook app on my Nokia 5800
2answers
Freezes and automatic shutdown
that's probably a software problem u sould go to a cellphone service and have'it resofted
Top Nokia Lands Phones Experts
Obehiaghe Adoghe
Obehiaghe Adoghe
Kolbrun...
Thomas Perkins
Thomas Perkins
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
