HP OfficeJet 7310 All-In-One InkJet Printer Logo
Posted on Oct 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an HP Officejet 7310 All-In-One. How do I set it up to automatically receive faxes. when Im home and not home. I have a fax pending and cant receive it right now. do I press * on my home phone?
Level 3:
  • HP Master 7,733 Answers
  • Posted on Oct 27, 2010
HP Master
Level 3:
Answers
7733
Questions
0
Helped
1863204
Points
21487
1helpful
How to set up fax number on my 7310 all-in-one.
According to the HP manual for this unit:
1. Verify that your HP all-in-one is set to answer fax calls automatically. (Press the Auto Answer button so the light is on.)
2. Press Setup.
3. Press 5, and then press 1.This displays the Advanced Fax Setup menu and then selects Answer Ring Pattern.
4. Press the down arrow key to highlight an option, and then press OK. When the phone rings with the ring pattern assigned to your fax phone line, the HP all-in-one answers the call and receives the fax.
You can download the manual from HP here if you've misplaced yours and need more setup information.
Unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
Cant recive fax
Ok - phone off hook is a message on the printer because you are on the phone. There is a phone that is up somewhere in your home that it can recognize. You cannot send a fax or receive and be on the phone at the same time. This can also be caused by credit card machines, internet service (filter needs to be on fax line), and other fax machines.
To the original poster - your question is fairly vague. This hp link solves the most common issues when you can send but not receive.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01503742&lc=en&dlc=en&cc=us&lang=en&rule=21569&product=391182
Faxing out
Press Menu button on the machine and than go to Advance fax setup and after than make the below mentioned chnaged
Error Correction Mode (ECM = Off
Automatic reduction = On
Regards,
Lalit
Fax
HI,
u need to make change to answer ring pattern from the front panel of unit .
Set the fax function to answer the phone automatically by pressing the auto answer mode button on front panel .
Thanks
My fax sound but dont received any fax
hi,
check whether the auto answer is turned on...
either u have the button on the front panel of the printer itself "auto answer" or u will have it in the fax menu...
press the menu button and scroll down to fax setup or advanced fax setup, make sure the auto answer option is turned on....
thanks and regards
agnel
1helpful
Fax - Using Vonage
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off. Try sending FAX.
Fax
you cant send? or receive?
Here is a troubleshooting guide from HP.
Make sure you follow carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&cc=us&lc=en&dlc=en&product=391182&dlc=en&lang=en
k24674
Grand Canyon Tech
Grand Canyon Tech
