Question about Microwave Ovens
Service manual for jura impressa x90 - Microwave Ovens
Posted by hasan_cirkic on
acehead
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Hi, I made a video how to fix your Jura step by step, good luck.
http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Posted on Mar 23, 2015
2 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: Jura Impressa x90 Machine. Steam portion
If the machine reaches the steam temperature and ther is no steam coming out of the spout, the problem is usually caused by a blocked steam pipe. Milk going up into the pipe and scale may restrict the wand blocking the steam flow.
To fix it:
Warm the machine is at coffee temperature , ensure that it is not at steam temperature.
Run some water through the sream wand by turning the steam knob.
If there is no water coming out out, use a long pin or a paperclip to unclog the steam. Do not force it over the steam attachment or you may damage the machine.
While doing the job ensure that you are not hurting yourself with the hot water.
Call technical support ringing the number on user manual if that does not fix the problem or if there is no water coming out of the pipe. The machine may not be reaching steam temperature because of a faulty thermostat or the steam valve may be blocked.
To prevent this future, after frothing milk, alway clean the wand running some hot water (steam will not work) through the pipe.
Posted on Aug 17, 2010
SOURCE: Jura Impressa X9 commercial coffee
Hello Krik,
Please visit the link provided below :
http://www.corporatecoffee.com.au/CC_images/manuals/man_1171847138.pdf
http://www.jura.com/home_x/products_commercial_use2/impressa_x9_win/accessories_impressa_x9_win.htm
http://www.jura.com/home_x/service_support/manual_home/manual-machines/download_manual_jura_impressa_x9win_english.pdf
Posted on Apr 23, 2011
Smh9187 microwave stopped working. The units display works, light inside works, vent fan works, but when you put food in it doesnt make a sound.
On model SMH9187B and SMH9187ST, one likely cause is a defective bottom door switch (primary interlock) or that switch's mount is loose, misaligned, or broken. The service manuals for these models are at my site here:
SMH9187B service manual
SMH9187W service manual 1 ' service manual 2
SMH9187ST service manual
Also see my help file on door switches here.
You can order Samsung parts by part number from the Pros here.
If it's not a door switch issue, it may be a blown high voltage fuse not to be confused with the line fuse) or a relay issue on the board, which I can repair for you.
If you have other questions, feel free to contact me at my site below for more free help.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 18, 2017 | In Microwave Ovens
Schematic or SERVICE manual for control panel pcb of Samsung microwave model MS123SCE
Most manufacturers will not provide schematics or service manuals unless you buy them. U might try to google for the service manual or the specific problem for the specific machine and read the hits for help.
Aug 27, 2015 | Samsung Microwave Ovens
I just went thru the entire decalcifying process and got to the final step, emptied the drip tray and coffee grounds bin, put the tray back into place, but can't get the display off of "empty...
You should Clean and dry the metal contacts on the back of the drip tray, ensuring that the gap between the contacts is clean and dry (if present, contacts not on all JURA models) Make sure that the plastic in between the contacts is clean
Sep 13, 2011 | Microwave Ovens
I need a service manual for Panasonic NE-1757R microwaves
Please find the service manual for Panasonic NE microwaves in the bellow mentioned link.
The link will open a pdf file with complete information.
http://web1.panasonic.com/food_service/cmo/servicer_information/pdf/NE1257R-NE1258R-NE1757R-NE2157R.pdf
Thank You for contacting Fixya.com
Aug 03, 2011 | Panasonic Microwave Ovens
I have filed my s7 Jura capresso machine with water but is still says fill system. How do I resolve the problem?
This an indicator of a magnetron issue, but there two other parts that can be a factor, the high voltage capacitor and diode. Depending on the nature of repair it could be as much as a new microwave oven.
Feb 20, 2011 | Microwave Ovens
Where is the thermistor
Many Microwaves do NOT use a thermistor, as such, they do however have thermostat type electronics, what you need to do is get a service manual, this will have a schematic diagram.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/280381a25d6e9bd885256e380058a213?OpenDocument
Above find a service manual for a generic service manual.
Jun 03, 2010 | Microwave Ovens
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
Microwave Ovens Logo
562 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
