Zyxel Prestige 334 Router Logo
Posted on Oct 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I forgot password of my zyxel 334 router, how can I enter the router without resetting its password.
Level 3:
  • Zyxel Master 7,733 Answers
  • Posted on Oct 28, 2010
Zyxel Master
Level 3:
Answers
7733
Questions
0
Helped
1864768
Points
21487
3answers
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords
Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next?
Login to Your ZyXEL Router Using the Router Password
Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: ===============
Forgot Router Password?
If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings.
What should you do?
Login to Your Router Using the Default Router Password
Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides.
Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!)
Find Your Default Router Password
Simply select your router manufacturer from the list below to display the default router passwords and usernames.
I HAVE FORGOT MY PASSWORD ROUTER ZYXEL P660HW-61
Hold down the reset button on the router for 30 seconds and that should reset it all to factory setting including the password, which should be on the bottom of your router
I cant reset my zyxel nbg 334w router even though i am doing as it says in the manual to reset it. Any helps?
Hold the button for sixty seconds. Use a watch to time this. If you've been unplugging the router before trying to reset, leave it powered on.
I HAVE FORGOTTEN PASSWORD FOR MY ZYXEL MODEM
If you forgot the WPA key and the password to log on to your router the only way to correct this is to reset the router by pressing the reset button for 10 seconds and then after that you need to reconfigure it back....
2answers
I'm trying to reset my lynksys router but can't get past the initial login. Don't know my old user name and password. Admin default doesn't work. States access unathorized
lower case admin is the password.Reset the router ,use a paper clip or a pin reset button between the ports hold the button down for twenty seconds.
try 192.168.1.1 in the address bar in Internet Explorer.When the log on appears type admin in lower case and hit enter you should be in the you can set up the router again.Remember to save settings on each page and copy the network key and store it in a safe place for future use.
Good luck
2answers
I have tried "admin" and "password" to get in to get my WEP key to add my sons netbook to our router, but it is not working. Can I reset the original login and password?
if you feel you are apart distance than other peoples wifi connections and safe,, then you can diable pass word in settings,,and log to your sons notebook..
4helpful
2answers
I have forgotten my password for my zyxel router. Is there anyway i can find it out? If not can it be reset, if so how do i do it?
If you forgot the password of your router. If ever you already change it from default, resetting is the only way now I know. If default consult your manual.
There's always a reset pin on every router. Go to manufacturer's site and download the manual for your particular model. Scan thru pages and look for Resetting the router.
Can anyone help me set up a dmz on this router(zyxel p 334)
Do you have a static IP to portforward with? i would not recommend DMZ because most routers lie - they still use a firewall even with DMZ.
I am unable to get into my Prestige 334 configuration screen
Read this its the manual for your router.
http://www.zyxel.com/DownloadLibary_ShortName/P-334/quick_start_guide/P-334_1.pdf
1helpful
4answers
Trying to configure zyxel nbg334w router
If the router will not connect to the internet, you will need to create the PPPOE internet connection with the username and password that your ISP provided. BPCS
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
