If it boots normally and there is no display on the monitor,it could be
1.Your Display card could have failed or the VGA cable from the display adapter is not connected properly to your monitor- In this case you will see a "no signal" message on your monitor.
2.If the monitor is powered on nothing appears,then your monitor most likely failed.
3.If the monitor's power on led light is not lit,then make sure your monitor is plugged in properly to the power source.
