My nokia 1600 looses signal completely all of a sudden, even though the battery is fully charged. The phone is 5 years old. I have not changed the battery ever.
If the battery is fully charged and still it does not turn on then either the power button is faulty or the phone. Did the phone get a jerk, because sometimes even a small thud can snap some connection inside as everything is so very delicate inside. Is it under warranty? if yes then Nokia Care is the answer.
there are few options by which this problem may rise .
* Old battery will not charge if its bulged. so get new 1
* Check if the charging plug in side th mobile has not broken.
* There mite be a short connection with the pin which will not charge the battery.
* take battery out keep it in sun for 5 mins and use it.or rub in 1 direction. mite work.
* If there is a problem with the board , check below
Symbol "G" and "E" are not related to this problem."G" means GPRS and "E" means Internet .The charging problem might comes due to bad charger or cgharging coil might fused or charging filter (IC) might sort.
Either your sim card is not seated correctly, the contacts are dirty, the sim card is dead, the copper contacts in the phone do not reach the sim card or the electronics in the phone are faulty. Try to change a new battery' check the battery terminal contact'. sometimes is not properly alligned' or maybe your battery is loose in tha back houssing of your phone.
try to change a new battery'
or maybe the sim card driver is unsoldered' or need to replace.
here is the pics.
skilled technician can do.
