Computers & Internet Logo
Posted on Oct 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IN DESKTOP SHOWING .......CRYSTAL XP THEME.WHEN I BOOT WINDOW XP FOR INSTALLATION ,IT DOES'NT BOOT......
Anonymous
Level 2:
New Friend:
  • Expert 43 Answers
  • Posted on Oct 27, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
43
Questions
0
Helped
4779
Points
129
When you put the cd in then restart the system and keep tapping F12 and then it will take you to one time boot menu then select the cd\dvd drive option and then hit enter and then it will boot from the cd and select the necessary for installation
1helpful
2answers
I cannot boot up my Microsoft Windows 7 due to a corrupt ntfs.sys file. I can access command prompt through computer or cd. Please help!
As you are able to access command prompt, you can run the "System File Checker" tool to repair/ replace the corrupted ntfs.sys file. To do this, follow the instructions below:
1.Restart your system and tap F8 key repeatedly until you see Advanced Boot Options menu on your screen. If you miss reaching the screen in the first attempt, repeat this step until you reach the screen.
2.On the Advanced Boot Options screen, select "Safe Mode with command prompt"
3.In the command prompt window, type "SFC /scannow" (without quotes).
Note: There is a space between C and / in the command above.
This will scan all your protected system files and replace the corrupted files with a cached copy stored in your system.
Important: Please do not close the command prompt window until the verification is 100% complete. After the process is completed, the scan results will be displayed on your screen.
To know more about System File Checker, you can refer to the following Microsoft support page:
http://support.microsoft.com/kb/929833
Hope this will help you.
GuruAid.com
I was able to download this zip file about a xp theme and i was able to unzip it already, but there's no executable file to istall my new theme. please help me.. thanks,...
Prepare Your Computer
  1. Because Micro$oft wants you buy everything from them, Windows XP wants theme files to be digitally signed. If they aren't then XP won't let you use the themes. You must first patch your uxthemes.dll file in your C:\Windows\System32 directory. This can be easily done using the Uxthemes Patch which you can download here. The patch supports Windows XP, SP1, SP2, XP 64 bit and Windows Server 2003. Run the patch, it will "fix" your uxtheme.dll file so you can use 3rd party visual styles. Disregard any warnings about files being changed, that is what we want to do. After you run the patch reboot your computer. Note: We recommend you create a restore point before running the patch just for good measure. We did not author this file we have used it our selves with no problems, use it at your own risk.
Install the XP Theme Files
  1. Themes are usually downloaded as a .zip file which must first be scanned using a virus scanning program, then unzipped to a temporary folder you can create on your desktop. Inside that folder you will most likely find a wallpaper image, .msstyles file, a .theme file and possibly a font file. it all depends on what the author has chosen to include in their theme package.
  2. If your theme package contains one or more font files (.ttf) copy them to your C:\Windows\Fonts\ folder.
  3. You may also find one or more .theme files (like axis.theme. Copy it/them to your C:\Windows\Resources\Themes\ folder. You will see a folder called Luna already in there, leave that alone, it is your existing Micro$oft XP Theme.
  4. Locate the .msstyles file, create a folder in the C:\Windows\Resources\Themes\ folder, I usually name it what the .msstyles file is named (like axis.msstyles so the folder would be axis).
  5. If you find a file called ShellStyle.dll, create a folder called Shell inside the first folder you created. Create another folder inside that called NormalColor. Copy ShellStyle.dll into the NormalColor folder.
  6. Most of the time you will unzip the file and everything will be properly ordered and only need to be copied to your C:\Windows\Resources\Themes\ folder.
  7. To install the wallpaper copy the wallpaper image file to your My Pictures folder.
How to Use the XP Theme
  1. While in your My Pictures folder that contains your wallpaper, click on the wallpaper file once to highlight it. In the menu on the left side of the window you will see at the top Picture Tasks. Click on Set as desktop background. You should see the wallpaper on your desktop.
  2. If the wallpaper needs to be stretched to fill the screen close the My Pictures window. Right click on the desktop, select Properties. The Display Properties window comes up, choose the Desktop tab. Your wallpaper should be highlighted in the list, using the Position box choose if you want it Tiled, Centered or Stretched.
  3. While in Display Properties if your theme had a .theme file select the Themes tab and select your theme from the list. If your theme only had a .msstyles file go to the Appearance tab and select your theme from the Windows and Buttons list.
  4. After you are done making your choices you can go to the Themes tab and save your theme by clicking Save As..., and then name it something.
  5. That's all there is to it and all without buying any programs.
2answers
Dell Dimension 4700 can not install Windows XP
It looks as though when deleting the OS you might have gotten jacked and the rom drivers were lost.
How can we find theme
here's the list of website which can be helpful
www.themexp.org/
www.xpthemes.com
www.wincustomize.com
www.softpedia.com/get/Desktop-Enhancements/Themes/CrystalBlue-XP-Theme.shtml
centralgirls.com/tech/download/Windows_XP_Themes.html
THE INSTALLATION INSTRUCTIONS ARE THERE ON EVERY WEBSITE
My system was chenged the instal of xp theme original window,but it opens only in classic window
Right click on the desktop anywhere that there are no icons. Click on 'Properties' at the bottom of the menu that will have appeared. By default you will be at the window to set your theme. In the Theme field, click on the dropdown button at the right side of the field and select the Windows XP theme. Click apply and then OK to close the window.
Good luck, and please let me know how this works out for you.
Spoem
58helpful
11answers
Download
Hello I want to download Vista Theme for XP
Please
i want to download vista theme for xp ANKAJ SAMKARIA hello i am abhay. i want windows vista ultimate edition
abhay kumar
1helpful
14answers
Download window vista theme
If you download window vista theme for xp ,it will not work untill you install any third party software .install any 3rd party software and use the window vista theme in xp
Use the below links to download the software and have window vista theme.......
http://www.softpedia.com/get/Desktop-Enhancements/Themes/Universal-Vista-Inspirat-Brico-Pack.shtml
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
Regards :
dilip bagdi
Technical Associate
2answers
Problem with replacing the motherboard and keeping my old hard drive
Windows XP questions and answers CH000635, How to get into Windows XP recovery console without a Windows XP CD. CH000646, NTOSKRNL.EXE is missing or corrupt.
How to create a boot disk. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
How to erase my hard disk drive and start over. If you are running or plan on installing Microsoft Windows XP please see ... First, we recommend that all users wanting to simply install Windows NT use the .
How to use the Windows recovery console. Place the Windows CD in your computer and boot from the CD. ... To repair a Windows XP installation using recovery console, press R.
Good Luck, Please dont for get to Vote/Thank You.
Grand Canyon Tech
Grand Canyon Tech
