Question about HP C6280 All-in-One Printer
I just replaced all the ink cartridges and the message says ink system has failed turn the power off then on again,. i have tried several times and get nothing
Posted by ambereliades on
Anonymous
    Novelist:
  • 119 Answers
Hi Please follow the the steps given below Make sure that the printer's power cord is connected to the walljack (Avoid if there is any surge protector or extension cord) Take out all the ink cartridges Take a clean cloth, dampen it in distilled water and with that cloth clean copper contacts of the cartridges firmly Let them dry for 2 minutes Unplug all the cables from the back of the printer while printer is turned on (After closing all the doors that are open and also keep the cartridges out) After 2 minutes, plug in the power cable Put the ink cartridges in one by one, then close all the doors again Printer would start going through some maintence and then would start aligning the ink cartridges All the best!! Regards
Posted on Oct 27, 2010
Printer says Ink system has failed.One of the cartridges was missing for one month and since I replaced it this message shows.I did all as per HP support and is still not working.
sounds like the printing heads are clogged. try taking old cartridge and putting rubbing alchohol in it and try several times to print test page. you can also use q-tip to clean the area where the cartridge ink connects to cartridge holder.
Nov 04, 2010 | Office Equipment & Supplies
Printer screen reads "ink system has failed. unable to print. refer to printer documentation. error: 0xc18a0301. turn power off and then on again." i have tried turning it off and on repeatedly and every...
jusr solved this off an article. the *,#,123 thing only gets you a r0046 support answer no sytem configuration menu, so.........hit cancel the hold down canel, ok black and color buttons at teh same time, error message continues, keep holding all 4 and the power off with on botton, let sit for a few seconds, my have to restart a few times but maintenaince is done and volla-fit it. up your hp-let keep em honest. andy fecteau
Aug 26, 2010 | Office Equipment & Supplies
"ink system failed"
This could be an issue with the connectors to the chips on the cartridge, make sure the chips on the carteidges are clean then check the ones on the inside of the ink holder, POWER OFF before doing this as you could cause damage to the printer if powered on, lift the lid, wait for the rack to engage the centre then turn the power off at the wall.
Hope this helps
Paul
Apr 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
I get an error message "Ink system has failed",,what is this..I have replaced all cartridges, and still no good it then says carriege jam..nothing seems to be in the way, etc
I can only guess the printhead may be clogged, and you may have two things to try:
1.- Run several (>10) cleaning cycles, hoping it will unclog the prinhthead
2.- Try with brand new cartridges
I don't know if it will work, but ink ages, and it might have dried in the cartridge and clog the printhead. Fortunately, HP builds the printhead into the cartridge, so replacing it is cheaper than with other manufacturers.
OR
  1. ress the On button to turn the all-in-one off.
  2. Unplug the power cord from the back of the all-in-one.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the all-in-one.
  6. Press the On button to turn ON.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
Nov 25, 2009 | HP Photosmart 3210 Printer
Oxc18a0101 error message - C6180 All-In-One
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plugthe power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
Oct 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Cannot get LCD screen to show Replace Ink message
try this
1. Make sure your unit is powered and not printing.
2. Press the SETUP button and then use the select arrows until you see REPLACE INK, then press the COLOR COPY button. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Before removing the new cartridge from it's package, shake the cartridge 4-5 times. Do not shake the cartridge once it has been removed from the cartridge holder.
6. Lower the new cartridge into its holder, then press down on the top of the cartridge until it clicks in place. Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
7. Repeat steps 4-6 for any other ink cartridges that require replacement.
8. Once complete, please lower the scanner and press it down until it clicks into place. The EPSON Stylus RX500 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus RX500 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady. At this point press COPY to move back to COPY mode.
Caution: Never turn off the EPSON Stylus RX500 while the On light is flashing, unless the Stylus RX500 hasn't moved or made noise for more than 5 minutes.
May 20, 2008 | Epson Stylus Photo R300 InkJet Printer
HP photosmart3210 printer problem error message
The issue relates to hardware of the unit ,
unit can not be recovered or is almost certain to fail again, however we can Attempt to Recover Unit Once .follow the steps below .
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Reconnect the USB cable, and try to print a print job from the computer.
9. If the error is still there replace the unit.
it might help.
Thanks.
May 17, 2008 | HP Photosmart 3210 Printer
ERROR MESSAGE APPEAR AFTER PRINTER PREPARATION OCURING. THE ERROR MESSSAGE THAT APPEAR , INK SYSTEM FAILURE. INK SYSTEM HAS FAILED. UNABLE TO COPY, RCEIVE FAXES OR PRINT. REFER TO DOCUMENTATION. ERROR...
Ink System Failure is a Hardware Issue, which indicates that the Ink Delivery system failed to initialize.
I suggest you to perform the below the troubleshooting steps, if it doesnt fixes, then the printer need to be serviced or replaced.
1.Turn OFF the printer, unplug the power cable and the USB from the printer.Then Press and Hold the ON/OFF button for 1 minute and then reconnect the cables and try again.If it doesnt fixes, goto next step.
2.Remove the ink cartridges, Turn the printer OFF and Unplug all the cables from the back of the printer.Connect the Printer directly to the wall outlet.Turn it on and wait until u get a prompt to insert the ink cartridges.If it didnt work, go to step 3.
3.Remove the ink cartridges again and close the access door.Disconnect the power cable while the printer is ON.Now Press and Hold the OK and CANCEL button.While Holding the OK and CANCEL button insert the power cable and continue holding the button until u get a message "NVM Reset" or untill the printer goes OFF.Then release the buttons and press ON/OFF button.
4.If you still get the same error, then the printer needs to be serviced.
Thanks
Riz
Apr 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP C6280 All-in-One Printer Logo
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
