Re: I keep getting this message whenever I hit the button...
It's merely informing you of the current exposure settings. The sensor's sensitivity is at ISO 200 equivalent, the aperture is f/3.1, and the shutter speed is 1/60 seconds.
It's merely informing you of the current exposure settings. The sensor's sensitivity is at ISO 200 equivalent, the aperture is f/3.1, and the shutter speed is 1/60 seconds.It's merely informing you of the current exposure settings. The sensor's sensitivity is at ISO 200 equivalent, the aperture is f/3.1, and the shutter speed is 1/60 seconds.
You can't post conmments that contain an email address.
I don't think its anything serious but first try to update the phone go to settings-Device-check for update if you hit on update after performing update check and the phone is up to date I suggest you do a factory reset if does not resolve you need to reload the O.S contact a phone doctor for reload.
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
U mean "service ride control" is being displayed on the digital part of the dash cluster. It means one or both of your front struts or rear shocks could be bad. Just keep hitting that info button to clear the message until u can afford to take a $800 hit for just one. But u never know, u could get lucky and it may just b a wire(not likely).
Ok not sure if you mean whilst taking the picture or after, if this is whilst you need to select the picture mode i.e Auto, Sport, Night, etc, the camera will display the config on the screen for a few seconds, in this time hit the OK button this will set the picture to Liveview, you will be able to see them on the screen,
Now to see the pictures you have taken you need to push the review button and scroll through the images,
Let me know if this helps if not i will look into it more for you.
Whenever a call gets connected I get a message that "cipering not provided by operator . insecure connection." what do you mean this warning text message . how to get over with this problem w580i
This means the Traction Control System has kicked on. Your wheels
lost traction and it has actived. You can turn your TCS off by hitting
the button and then it will stay lit. The Acura automatically resets
this system to ON whenever you start your car so to turn it off you
will have to keep pushing the button to off
Message Alert: Go to Menu (four dots button at bottom left of main screen), Settings (cog button), Profiles. Ensure profile other than Silent or Vibrate Only is selected. Hit Menu/List button (bottom left) then Edit. Scroll down (using screen or camera focus ring) and ensure Message Alert isn't set to No Sound and select a tone from Message Tone.
Invalid picture messages: this is likely to be a carrier settings problem - either ring their customer service to get them to send you the settings (and ensure your account has MMS enabled) or download the settings via their web page.
Battery life: Try charging battery for 24 hours straight. Also ensure bluetooth is off if you're not using it. Turn Screen Brightness down and ensure backlight is set to 20 secs max. This will help extend battery life.
Make sure you dont have a disk in the tray.
Hit the Pal.ntsv button 2-3 times.
You will get the picture back.
If not, then you also hit the p.scan button.
Hit that button 2-3 times till you get the picture back.
To reset waste tank full error in MP730. 1. Hit the "menu": Key 2. Hit "Copy" Key 3. Hit "#" Key 4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading 5. Hit the "3" button- this will bring up Eprom Clear 6. Hit "0" button 7. Hit the "Stop" button Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
