You can program to regular (analog) antenna channels. To do so you must use the original remote which has a TV/DTV switch in the top right corner of the remote. Choose the appropriate mode for the type of channel you want to see or scan for. Here is a link to the owners manual and a picture of the remote swithc. The info on the signal switching is on pg.13.
http://tv.manualsonline.com/manuals/mfg/funai/cr130dr8.html?idRes=707655
Hello, this model number does not have the atsc(digital) tuner, which means that you'll need a digital converter box to use this TV with an antenna, Here is the spec sheet for this TV: Television system: NTSC-M TV Standard Closed Caption System: §15.119/FCC Channel coverage VHF: 2 ~ 13 UHF: 14 ~ 69 CATV: 2 ~ 13, A ~ W, W+1 ~ W+84, A-5 ~ A-1, 5A Tuning System 181 channel frequency synthesized tuning system Channel access: Direct access keyboard, programmable scan and up/down Terminals Antenna input: VHF/UHF/CATV 75 ohm unbalanced (F-type) Video input: RCA connector x 1 Audio input: RCA connector x 1 Earphone: 1/8" monaural (3.5mm) ELECTRICAL SPECIFICATIONS Sound output: 1W, 8 ohm OTHER SPECIFICATIONS Remote control: Digital encoded infrared light system Operating temperature: 5°C to 40°C (41°F~104°F) Power requirements: AC120V, 60Hz Power consumption (Maximum): 53W Picture tube: 13" Dimensions: H : 12-3/4"(323mm) W: 14-1/8"(358mm) D : 14-4/9"(367mm) Weight: 19.0 lbs. (8.5kg) •Designs and specifications are subject to change without notice and without our legal obligation. •If there is a discrepancy between languages, the default language will be English
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
• You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
• If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
• If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
• To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
• Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
