RTO Wall Lenk Corp. LG2000K Soldering Gun Kit Logo
Posted on Oct 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need 2 know how 2 take temp of Lenk soldering gun model 2000.not sure if its getting 2 correct temp.whats temp supposed 2 be,in ferenheit?i have a Etex digital multimeter.really dont know how 2 use it though.
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
  • Posted on Jan 08, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1510955
Points
12435
It needs to be at least 600 degrees F and should reach 800 or so. 60/40 solder melts around 600, but flows better at about 700 degrees. Most soldering guns require a on-off-on--- sequence to keep the tip at proper temperature. If your gun doesn't seem to be heating, try tightening the tip nuts. Hope this helps!
98 Buick Century. Temp gusher pegged when cold,odometer reads error, gear selector says 2,& oil light comes on when cold.
I agree , if it were only one area of error I would first and foremost say verify your temp with a point and shoot temp gun , but it sounds like you need new cluster , I'm sure the other Answer is also correct to re solder the components , but most just want it fixed quickly . I would also remove battery so when re installed your cpu re sets
LSP-60 i have filled it with butane and no gas is coming out now....it was working just a minute ago.
Hello, if does work and leaking fuel. Take it back to Sears for a replace. Do mess with. If does work right the first time then it is faulty. GB...stewbison
Gun will not heat up tip unlesss it is pressed kind of hard against material? is this the way it is supposed to work...?
This sounds like a "contact" problem where the tip installs in the gun. I would remove the tip and burnish the connections with some very very light sand paper or steel wool (an emery board is a nice 'tool' to add to your tool box). You'll also need to clean the gun connections themselves. Also make sure the connectors are tight, but be careful not to overtighten them or you'll break them. Good connections = good heat transfer. Good Luck.
James
2answers
Need to know where I can get tips for a 8200 gun.
Sears Hardware carries Weller and and has tips for the 8200 Weller Soldering Gun, I just swa them yesterday at Sears Hardware.
Motorcycle magneto there is a broken blue wire on on my sons bike i dont know the make or model it has 6 copper coils
Get a soldering gun and solder the wire back together. Use another piece of wire as a jumper if the existing wire is not long enough.
1helpful
I have a hunter 44150B thermostat and when i replaced the batteries, the temp is in celcius instead of ferenheit...HELP!
Pull the whole thing off the wall there is a switch on the back marked F and C. Make sure the switch is set correctly.
Broken wires
if its not too far burned back into the gun body, get some "HI" TEMP" terminals and recrimp...you should be fine....dont peel back into xfmr windings though
Removal of the bulging barrells
have to be resoldered . you will need a very high temp soldering gun to remove these ..this solder is not like the old lead solder that unsolders easy also make sure they have same rating as original or higher voltage and also make sure polarity is correct when replaced..goodluck
Top RTO Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
