The process of changing ink cartridges varies slightly by the make and model of your printer. Open the cover to the area where your cartridges are installed while your printer is turned on. If opening the cover automatically prompts the inks cartridges to move and center in a position where they are accessible, then all you have to do is remove and reinstall new ones. If the cartridges do not automatically move and center themselves where they can be changed, then your printer requires an additional command that you do manually to make this happen. Some printers require the user to push the power button down and hold it for 10 seconds to have the machine move and center the cartridges in a position that can be reached easily by your fingers. Some even have an extra button to push that has a little picture of an ink drop next to it which brings the cartridges forward for replacement. If you cannot reach the cartridges easily, or opening the cover does not automatically move and center them then check your manual for the procedure or repost your question inlcuding the make and model number so that we can locate this information for you.
Lets move forward.
Once the cartridges are in an area that is easily reachable, the next step is to eject the cartridge which needs to be changed. This procedure can also vary by make and model. Look at your cartridges and check for a plastic ejection lever in front that can be pushed down by a finger tip. If you see one, push downward and see if the cartridges is ejected outward towards you. If it is ejected, then replace with new cartridge and push downward to lock it into place and your done. If there is no plastic ejection lever in front of the carriage which holds your cartridges, then place one finger on top of the cartridge you wish to remove and push downward slightly and pull it towards you until it unlocks and releases it. Then remove and replace and push down and forward to lock the new one by into place and your done.
I can give you specific instructions pertaining to your make and model printer if you supply this information on the website. Good luck!
on what printer
