OK - well "look" blown may not be a solid, engineering approved, check. You could take the fuse down to a local Radio Shack and have them test it. Good news is that they will probably have a replacement if you need it. OTHERWISE... Keeping the volume WAY down - you can try another speaker on that output. It doesn't really have to be a woofer, just something to verify the circuit is working. That should tell you if the pathway is good which then tells you if its the woofer or the amp/receiver.
