Question about Water Heaters
I have an AO Smith Model EES 52 917 hot water heater. This morning my hot water suddenly disappeared. I have tried resetting the breaker with no luck.. I am not sure what else to try.
Posted by erikafloyd on
Anonymous
You have electric water heater.
Inside the upper panel on water heater is a thermostat with red reset button.
1) Click the reset.
2) Put insulation back over thermostat so it is not exposed to cooler air, so it reads correct temperature.
After resetting thermostat, you will have hot water.
The reset automatically clicks off when thermostat detects temperatures in excess of 150 degrees.
The re-set is a safety device, and it keeps everything safe.
If reset will not 're-set' with cold water in the tank, then thermostat is bad, replace thermostat.
You can repair electric water heater yourself following steps on links below
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If the reset clicks off again, just reset it
This is not a dangerous situation
Reset thermostat as many times as necessary until you can fix the problem
If you have trouble fixing the problem, add a comment at bottom of this page and it sends me an e-mail and I will help further
Thermostats with ECO red reset
Posted on Oct 26, 2010
  • 3 more comments
  • erikafloyd Oct 26, 2010
    I tried the reset switch with no results. The water heater has two thermostats, an upper and lower, which one would need replacing?
  • Anonymous Oct 26, 2010
    The lower thermostat cost a few dollars more, so buy them both.
    I will be back at my computer around 10CST, and will look for your e-mail if you have problems.
    The instructions on the 2 links above are complete, but water heaters have new surprises.
    Don't forget to take a photo of your thermostat wiring so re-connection is EZ.
  • catdaddymomm Feb 04, 2011
    I just moved into a foreclosure home. the house been sitting for about 8 months. the water in the tub and shower on both sides of the home is barely coming out. The water does not get hot in any of the sinks as well. I have an electric water heater model number EES 52917. Can someone give me some advice please
  • Anonymous Feb 04, 2011
    It sounds like 2 problems. Hot water heater not heating, and low pressure. Link on answer above goes to troubleshooting for water heater not heating. For low pressure, open next link:http://www.fixya.com/support/t7884953-am...
  • Anonymous May 13, 2011
    upvote the answer
How do I set ao smith pro max model ect 52 on vacation mode
No vacation mode in this heater. I have used this for last 5 years.
Dec 18, 2014 | AO Smith A O Smith Water Heater Hot...
No hot water - the light shows red. It has had problem in the past months but cutting the power off and back on seemed to reboot the computer. This time the light stays red.
Before calling service technician:
Click following link, the click product, then scroll to page bottom to tab that offers technical literature, and download service manual and operation manual.
http://www.hotwater.com/water-heaters/residential/hybrid/
Read the required installation and maintenance protocol to see if air filter has been cleaned regularly, or the condenser coil might be dirty.
Required maintenance can be done by service tech recommended by AO Smith.
Contact AO Smith to find trained person, and next time, do not install expensive water heater since all savings disappear with service issues.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 08, 2013 | AO Smith PHPT-60 60 Gallon Voltex...
Installation: Electrical Requirements
13Mb product manual is a big download ... electrical info page 13:
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-gas-water-heater.pdf
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-electrical-connection.pdf
Recommended both water heaters require dedicated single-phase 15 amp 120Volt line with correct polarity. This is 14 gauge wire and 15 amp breaker for each unit.
I would put both water heaters on surge protection and GFCI. Most water heaters are not protected from surge, and manual says line noise can affect operation of water heater.
Your local code would say if GFCI is required. Install GFCI breaker in main panel if required.
Install inline surge protector: Or add main breaker box protection.
http://www.amazon.com/dp/B003AU0Z48/?tag=waterheaterti-20
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Add a comment and say what you discover
May 17, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
I NEED TO REPLACE THE ELEMENTS ON A AO SMITH MODEL EES 52 917 ARE THEY SCREW IN OR BOLT IN
1) Copy following link to identify element type, and see step-by-step instructions:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
2) Almost all elements today are screw-in type instead of bolt-in.
Literature shows EE series is standard 1-1/2" screw-in ... assuming your model matches literature.
3) Buy generic element from local hardware.
If elements burn out frequently, then install lower wattage.
Feb 04, 2013 | Water Heaters
AO Smith Water heater FPSH50-260 keeps blowing fuses
FPSH series is a power vented residential gas water heater.
1) The blower is plugged into 120Volt outlet. If blower has short, then it will trip breaker.
Blower could be Fasco model 7021-10195, or 7021-10770. Call AO Smith: 1-800-527-1953. They will need model number and serial number located on label on side of tank.
2) Before calling AO Smith, check outlet with circuit analyzer. Outlet must have correct polarity and must be grounded. Unplug cord to water heater and run continuity test from ground prong on electrical plug to manifold tube on gas valve.
3) Also if a fluorescent light fixture is on the same breaker, that can cause burner to short cycle.
4) Connect water heater to different outlet and see if problem continues.
5) AO SmIth has service manuals for the FPSH series that download to your computer:
Sep 20, 2011 | Water Heaters
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a hot water heater model # EES 52917. It is 8 years old. The tank has rusted around the top heating element. Why has this happened and what can be done about this issue. From what I understand...
AO Smith is biggest manufacturer and ships about 140,000 units per month sold under different brands. Look at rating on tank. Is it a 9 year tank? Or 6 year? Or lifetime?
http://waterheatertimer.org/Water-heater-manufacturers.html
Number of factors can cause rust around element:
1) Element is seeping moisture: check and replace element.
Elements can start leaking any time
http://waterheatertimer.org/Water-heater-is-leaking.html
2) Anode rod can be depleted from variety of factors including water softener or calcification over anode so it will not work: Check and replace anode rod every 1-2 years with water softener, every 3-5 without water softener. New anode rod will STOP the rust, but will not repair tank that is rusted.
Tanks with longer warranties have 2 anode rods, one on hot water nipple, the other on top of tank.
http://waterheatertimer.org/Replace-anode-rod.html
3) Stray current corrosion: add a jumper wire between hot and cold pipes, and make sure tank is grounded. If there is stray current, it will deplete steel in tank if tank is not grounded.
For example one fellow had a tank that rusted out every few years until he discovered his big radio antenna was grounded back to hot water pipe and the tank was not grounded, so the interference depleted his tank.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#Ground-tank
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 23, 2011 | Water Heaters
Burner didn't ignite on my AO Smith model FXGT/PGXT
Unless your AO is a high recover it will take a while for it to fill up with the water that you have used then reheat the water in the tank.
Nov 12, 2008 | Water Heaters
Water Heaters Logo
7,061 people viewed this question
Top Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Water Heater Expert? Answer questions, earn points and help others
