there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
look for a stuck or otherwise malfunctioning water fill valve. one way to check, turn the machine off and see if the water is still running to fill it. start with that and let me know.
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
when you first turn the machine on it will go through 2 fill cycles. turn the machine off, and drain the water reservoir. when you turn the machine back on the first fill cycle should fill the reservoir and over flow a little bit. If it does not overflow then you are not getting enough water (change the fill valve). If it does overflow on the first fill cycle, the the machine probably needs acid cleaned. the instructions on acid cleaning are usually on the door. I don't believe the computer board would be your problem here. Hope this helps, CLINT
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
