Question about Hobart 24 in. LXIC-5 Built-in Dishwasher
I constantly get the "E4" error every time I turn
Posted by franky428 on
stravage
  • 4 Answers
1. Low water pressure - check for clogged hose strainer; ensure
the site water pressure meets minimum flow pressures.
2. Make sure probes are clean. (See Cleaning.)
3. No water pressure - main water supply valves may not be
working.
4. Anti-siphon valve - located in the lower left area of the chamber
just above the water line. Drain the machine and insert a toothpick
or similar object into the hole to verify ball (" OD) is free to float.5. Delime machine.
Posted on Oct 06, 2017
5 Related Answers
Anonymous
  • 25 Answers
SOURCE: Integrated dishwasher DW009,
If this is an asko dishwasher , most times this problem is caused by water getting into the base pan and setting off the float switch. Turn off the power and take the toe kick off, behind there is a pan runs under the motor and sump if there is water in it clean it out. that will take care of the problem. but you will need to watch and see if you can tell where the water came from sometimes on those unit its just from too much detergent
Posted on Jan 25, 2008
Anonymous
  • 170 Answers
SOURCE: E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Posted on May 19, 2009
Anonymous
  • 640 Answers
SOURCE: Hobart lx18 Dishwasher wont fill up
Frank,does the sump probe (the one underneath the screen) look good?It should have at least one quarter inch of metal.I have seen these break and its hard to tell but the info your describing sounds like that probe is bad or the control board.I'm a hobart tech and can help you troubleshoot,let me know----Tony
Posted on Nov 22, 2009
SOURCE: error code e4 flashes on belling dishwasher idw604
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Posted on Apr 19, 2010
Anonymous
  • 10 Answers
SOURCE: dishwasher is displaying error E4
normaly its the heat element or the heat sensor
Posted on Sep 24, 2010
3answers
Hi i just bought Electrolux Dishwasher ESF2433W When i first time turn it on, the "Normal" button light keep on flashing with beeping sound. According to the trouble shooting manual, it actually refer to...
If you just bought Dishwasher ESF2433W I suggest you contact an authorized service center because the appliance is under warranty..
E4 : if overflow micro-switch is act and keep for longer than 2 seconds, the E4 would occur. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown.
Sometimes defects are generated by incorrect transportation appliances so that should be taken into consideration.
Dado
1helpful
2answers
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
1helpful
3answers
E4 error showing on a kelvinator kd14ss
good day
my dishwasher give e3 and e4. what is the problem and how can we solve the problem.
1helpful
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
1helpful
Hobart commercial under the counter diswasher LXIC Model Number 130016. DELIME light comes on every day at startup. Machine will immediatly run (in DELIME mode I think) for about 5-10 min and then get E4...
The machine is trying to tell you to delime it. After a certain number of wash cycles, the LXI dishwasher reminds you to run a delime cycle (instructions are on a label on the bottom of the dishwasher). Judging from your posting, it's been ignored for quite some time, so you may need to run multiple delime cycles, depending on how much scale is built up inside the machine on the probes, wash arms, rinse arms, drain body (though you can't see this part, heavy scale deposits will cause draining problems). So . . . . get some good strong delimer and run a few delime cycles (talk to your chemical supplier about delimer - don't buy some weak stuff like LIME-A-WAY off the shelf).
Once you've delimed the machine, your E4 code may go away. E4 is the dishwasher's way of telling you that it did not fill properly on the initial fill (when you first turn on the machine). More specifically, it means the dishwasher DID NOT SENSE WATER at the upper probe at the rear right of the tank (there are two probes back there, on one assembly, referred to as the MIDDLE and UPPER water level probes). The probe may be coated with lime causing difficulty sensing water at the probe, so a good deliming may clean the probe and fix the E4 problem (in fact, reach back to the probes and break off any heavy built-up lime/scale deposits before deliming). If the E4 code persists after deliming, watch the pressure gauge on the front of the dishwasher. If the gauge reads lower than the green area, you need to adjust or replace the water pressure regulator. If the E4 problem still persists, replace the probe assembly at the rear of the dishwasher.
Hobart commercial under the counter diswasher LXIC Model Number 130016. DELIME light comes on every day at startup. Machine will immediatly run (in DELIME mode I think) for about 5-10 min and then get...
Q have your run a descaler . to rid the machine of its deposits . in order for the machine to run properly the parts and pump / screens must be clean . / descaling for deliming . dishwasher and icemakers is common practice . and then i belive the light will not come on . .. hope this helps mm feed back pls
2answers
Hobart dishwasher lxic detergent pump will not run
it supposed to work throgh the washing cycle,therefore you better trace,and inspect the line of the detergent,maybe it'stuck somewhere,and if it's ok check the panel board.does the pump receive voltage through the washing cycle.
Hobart LX18 E4 Error. Where can I get a manual?
this is asensor error unit not filling fast enough or loose connection
5helpful
2answers
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 • Dishwashers
Hobart 24 in. LXIC-5 Built-in Dishwasher Logo
Top Hobart Dishwashers Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
