Question about Whirlpool Freezers
How long should it take for a 18 cu ft. chest type deep freeze to get cold?
Anonymous
    New Friend:
  • 27 Answers
From room temperature if just plugged in rule of thumb is 24hrs to properly reach temp. Place a glass half full of water in shelf when is frozen solid the unit should be plenty cold enough to keep food. It is always a good idea to get a small fridge thermometer to make sure of temp.
Posted on Oct 26, 2010
Testimonial: "Thanks, your answer was very helpful."
I have deep freezer chest that does not freeze but when you plug it in you can hear it click on but will not get cold at all has been unplugged for a few years but stored in a dry building
If it doesn't get cold at all, then your compressor is not running. Which could be the start relay or start capacitor or even the compressor. The relay and capacitor are not that expensive and pretty easy to replace, but if it is the compressor then you might not want to put that much money into an older unit.
Aug 13, 2011 | Haier 5 cu. ft. / 142 liter Chest Freezer...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    My deep freeze locks on its own. We dont have a
    nothing to do with temp changes. only to do with a broken lock mechanism.
    Jul 26, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
    How to close the deep freeze
    click on it with shift and type your password and restart the computer
    Jun 19, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
    Only one half of my chest type freezer freezes? It is old. Bought at least 18 years ago. Help!
    My recommendation is to get rid of this 18 year old freezer as it is costing u a fortune to keep it plugged in. Then ask yourself if you really need an additional freezer at all?? If you do, consider purchasing a new small one that is really energy efficient. You will be way money ahead I assure u.
    Apr 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
    Kenmore 23.1 cf Chest Freezer not cooling below 14F
    Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
    Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
    Freezers Logo
    1,133 people viewed this question
    Top Whirlpool Freezers Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Dennis Boxerman
    Jim
    Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
