Question about Frigidaire Electric Dryer
Affinity dryer with a e31 error. What should i do?
    New Friend:
I have the same problem . The store replaced it with a brand newnew unit - SAME E31 error code appears and there is no solution
Posted on Nov 15, 2011
6ya staff
SOURCE:
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
Jul 28, 2015 | Washing Machines
Tip
Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
Hi.
This error codes apply to Frigidaire Affinity washers and dryers:
E11 - Fill time too long.
E13 - Water leak in tub, or air leak in air bell.
E14 - Reed switch.
E21 - Water not pumping out fast enough.
E23 - Drain pump relay on control board failed.
E24 - Drain pump relay on control board failed.
E31 - Pressure sensor not communicating with control board.
E35 - Pressure sensor indicates water overfill.
E41 - Control board indicates door switch is open.
E42 - Door remains locked after cycle is completed.
E43 - Control board problem
E44 - Control board problem.
E45 - Control board problem.
E46 - Control board problem.
E47 - Control board is sensing the door PTC circuit is open during spin.
E48 - Control board is sensing the door PTC circuit is closed.
E4A - Program Timeout Fault.
E52 - Bad signal from tacho generator.
E55 - Motor overheating.
E56 - High motor current.
E57 - High current on inverter.
E58 - High current on motor phase.
E59 - No tacho signal for 3 seconds.
E5A - High temperature on heat sink.
E5B - High temperature on heat sink.
E5C - High temperature on heat sink.
E5D - Communication problem.
E5E - Communication problem.
E5F - Communication problem.
E67 - Input voltage on microprocessor incorrect.
E75 - Water temperature sensor circuit (digital readout models only).
E76 - NTC temperature for the cold water valve over the limits
E95 - Communication error.
E9E -Voltage error.
EB1 - Incoming power frequency out of limits.
EB2 - incoming line voltage above 130 VAC.
EB3 - Incoming line voltage below 90 VAC.
EF1 - Clogged drain pump.
EF2 - Too much soap.
on Apr 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Clear codes for affinity dryer
Hi Friend, this is Z. I am happy to assist you!
I see that you have a Frigidaire Affinity dryer and I'm presuming you are seeking information on how to clear error codes on your dryer. May I please have your model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can help pinpoint the exact problem. In the meantime, you can reset your dryer by either unplugging your dryer or flipping off the breaker for roughly ten minutes. This often clears most false error codes. Hope this helps!
May 21, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
White westinghouse dryer
Hello Mizar - Thank you for allowing me to assist you. If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
May 29, 2013 | Electrolux Dryers
E31
Hello Stephanie - If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
May 02, 2013 | Frigidaire Affinity ATF7000E Front Load...
E31
Hello Smithysarah,
Welcome to fuixya,
You said, HI MINE READS ERROR E31 WHAT DOES THIS MEAN?
E30 or E31= Motor Drive Problem -
Run the programme again,
if problem persists call for
a Service Engineer.
I will tell you a secret.
Try unplugging the washer for 5 minutes and then we will see if this has reset the system!
like rebooting your computer.Some times it is only a glitch and no mechanical problems are there!
If so you saved a service call.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Thank you.
Waiting for your results!
Sep 30, 2008 | Hotpoint Ultima WD72 Front Load...
Error / Pause Affinity ATF7000
OK i had this , 2 times, take the seal off and then take the door latch off and unhook all the plugs and wait 6 min then rehook everyhting and turn it back on and wait a couple min then try
Feb 02, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire  Electric Dryer Logo
365 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
