Question about HP iPAQ rx4240 Pocket PC
Screen flickers fron the right on my ipaq rx4240 please help
Posted by barrie_mo854 on
Anonymous
    New Friend:
    Problem Solver:
  • 19 Answers
Posted on Oct 26, 2010
Need drivers for HP Ipaq RX4240 to sync with Windows 7
You can obtain all HP products & services for support for each product here at this link below, hope this helps....
https://support.hp.com/gb-en/document/c01121139
Jan 25, 2018 | HP iPAQ rx4240 Pocket PC
Hp rx4540.How to access the Boot loader mode?? .My ipaq just displays the hp logo on start up and then just freezes.Ive tried soft and hard reset.Help please
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
http://www.wonderhowto.com/how-to-repair-hp-ipaq-rx4200-rx4240-rx4500-rx4540-243534/view/
Mar 11, 2010 | HP iPAQ rx4240 Pocket PC
My backlight quit working while I was trying to
Either the inverter is shot or the light bulb itself. There is not much you can do about it except for sending it back to HP for repair.
Oct 02, 2009 | HP iPAQ rx4240 Pocket PC
Wont work with a windows vista laptop??
you need to install the software that is the interface to the hardware. also depending on how old the hardware is it might not be compatible with vista
Apr 25, 2009 | HP iPAQ rx4240 Pocket PC
Hp 4700 ipaq does not display properly
Take a firmware update to your Hp 4700
Mar 26, 2009 | HP iPAQ HX4700 Pocket PC
Ipaq h5455 wont stop wibrating and i cant reset it
try a hard reset - it will restore to the original state. it removes all files and programs in the memory files in a storage card wont be affected.
Just hold down the calendar and today buttons, these are the two outer buttons on the lower left and lower right, then using a stylus press and hold for at least ten seconds the soft reset button this is located on the lower right edge of the unit. The screen should reset and the iPAQ will boot up again.
Mar 21, 2008 | HP iPAQ H5455 Pocket PC
Failing to power up.
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Sep 03, 2007 | HP iPAQ H5450 Pocket PC
HP iPAQ 3715 - screen problems
Return it as faulty. WiFi should not impact your screens ability to stay on.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ rx4240 Pocket PC Logo
Top HP Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
