Question about La Crosse Radio Controlled Atomic Clock
My LaCrosse radio-controlled WT 3144 clock is ticking very fast! The minute hand takes 8 sconds to make 1 complete rotation. The second hand ticks in place every second. During this moment the minute hand pauses. Correction -- the second hand will advance 4 seconds while the clock is in a horizontal position.
Posted by pamdosenberr on
David Dunn
    Brigadier General:
  • 8,546 Answers
I'd say you have a lemon.
Manual:
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
For warranty work, technical support, or information contact:
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail
[email protected]
(warranty work)
[email protected]
(information on other products)
Website
http://www.lacrossetechnology.com/
Posted on Jan 19, 2011
HI I live in Hawaii we dont go by pacific time zone like California how do I set my clock WT-3122A
Aloha. Try asking your question here: Clocks Watches Questions . They helped me before with an antique clock problem. Good Luck.
Oct 04, 2014 | La Crosse Technology WT-3122A 12.5" Wood...
I have model WT:8029U solar power clock. How do I set it to Mountain Time?
If you have the LaCrosse WT-8-29U, it isn't hard to set the unit manually. After the unit receives the signal from the NIST radio station and sets itself (or fails to receive the signal), turn the clock around. (If you have it on a wall, take it down first.) Press and release the Set button (left-most button). Then press the + key (the button to the right of Set) to toggle through to MST. If you press and release Set again, you can use the + key to toggle DST on and off.
The manual for the WT-8029U is available here: http://www.lacrossetechnology.com/8029/manual.pdf .
I hope this helps.
Jul 19, 2013 | Audio Players & Recorders
Minute hand on atomic clock keeps moving
Take the battery out and put it back in the opposite direction. Wait 5 seconds. Put it back in the correct position. The minute hand will go around very fast and eventually come to a stop. This can take a couple days. That means it is waiting for a radio signal from Colorado. For a better signal, place the clock in a window that is facing Colorado. The minute hand will begin to spin very fast until it stops at the correct time. Again, this could take up to 2 days.
Sep 12, 2012 | Staples Round Atomic Wall Clock; 14
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
The second hand on our LaCrosse atomic clock has stopped moving but the clock continues to keep perfect time. How do we get the second hand turning again?
The manual for one of their clocks says the clock will change the second hand to two-second intervals to conserve energy when the battery voltage gets low. Perhaps your battery is VERY low.
Mar 25, 2011 | La Crosse Radio Controlled Atomic Clock
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Jan 24, 2011 | La Crosse Radio Controlled Atomic Clock
We have an Atomic Lacrosse WT-3143A clock; the battery ran out and a new one was put in. The hands rotated and stopped at 8 o'clock. We pushed ET buttons on the back and nothing happened, pushed the...
Directions:
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail:
[email protected] (warranty work)
[email protected] (information on other products)
web: www.lacrossetechnology.com
Sep 02, 2010 | La Crosse Radio Controlled Atomic Clock
Second hand stops, then ticks four ticks very fast then stops,
It may be that the battery is getting near the end of its life.
May 05, 2010 | Tag Heuer WAH1112.BT0714 Formula 1 watch
How to stop clock ticking
It isn't that hard to get the clock to stop ticking.
Disconnect power to stove so that you do not get a shock.
Take off back panel screws behind the clock.
disconnect the wires to the clock.
Make sure that the wires are not touching anything metal. If they are not insulated, you will want to tape them.
Do not use the hammer to the dial method to get the clock to stop. It is fast but may cause damage.
Apr 15, 2009 | Kitchen Ranges
La Crosse Radio Controlled Atomic Clock Logo
563 people viewed this question
Top La Crosse Home Experts
Are you a La Crosse Home Expert? Answer questions, earn points and help others
