Question about Panasonic PV-DM2093 Triple Play 20 in. TV/VCR/DVD Combo
We bought a used Panasonic Triple Play 27" and have been unable to get the DVD player to work. It reads the disc (standard DVD) and they says something along the lines of "This type of disc is not compatable. Please insert a disc in a compatable format". We bought the TV in the US and are playing US DVDs so I don't know the problem. Any ideas?
Posted by spluim on
Anonymous
    New Friend:
Panasonic DP1820p copier error code is Add papar to tray1 when you on the copier
Posted on Oct 26, 2010
  • Anonymous Oct 26, 2010
    panasonic DP1820p copier error code is Add papar to tray1 when you on the copier
DVD player will play store bought dvd's but will say unknown disc when I insert one from Netflix.
Is it possible that this is a Blu-Ray disc from Netflix? If so, It may not be able to be read on a standard DVD player.
Another possible reason for this is that the disc is somehow damaged and thus unreadable.
I'm afraid without seeing the disc I am unable to help you further.
Either way, might be time to complain to Netflix:
Netflix Customer Service(800) 279-5688(888) 638-3549(800) 585-8131
Sep 06, 2012 | Zenith XBV243 DVD Player/VCR
Dvd player gives message "this
Tries many more DVD discs tries to check it out as the disc u insert in the DVD player tray have difference region format disc that why u getting that answer.
Jun 05, 2011 | Panasonic PV-DM2792 Triple Play 27 in....
When trying to play a computer generated DVD +R DL, I get a message that says this type of disc cannont be played. please insert a different disc
The disc is probably an incompatible format for this model player. Even if the disc is finalised in your PC, or in a DVD recorder, this player may still be unable to read it. Some DVD recorder/players do not recognise DVD+R (or +R DL) media, while others won't recognise +/-RW discs (except CD-RW); this is a model limitation - not a fault with either your player, the PC burning software or the discs themselves.
Nothing can be done to fix this except purchasing a model which accepts multimedia (+R/DVD-RAM etc). The question is, does your player play ANY normal DVDs? I am guessing your player will accept DVD-R DL discs just fine since this is standard as well as proper shop-bought movies.
Feb 19, 2011 | Panasonic DVD-S35 DVD Player
I have a Sony DVD player (bought in 2004) and while it will play a new DVD once it will not play again. I've bought a DVD player cleaner, but it still won't play my DVDs (Error appears each time).
Tries wash all ur DVD Disc with dishing soap to clean out all the smushes,grims,oil from the finger prints,on the laser surface of the disc,it should play now.Not than u must take the tv aparts take some Q tips with some rubbing alcohol to clean the DVD laser eye it self.Long time DVD laser eye reader have contaminate from the air cause it not read discs.Especially house hold that smoke or live in dries heat states.
Apr 14, 2010 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Problem with the dve player
You may have to check the options for the player. Some DVD players cannot play formats other than regular DVDs. You can check the options to see if it can be put in a different mode from the normal one, such as progressive scan, which can help it to read DVDs better in some ways. You can also set it up to accept more types than just DVDs, but also DVD-Rs and VCDs. I cannot tell you, without fiddling around with it, whether you will need to take it in to a shop, but that is an option. Once you see about adjusting some of the settings, see if it won't play a DVD.
Oct 23, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
My Panasonic TV has a built in DVD player. Won't read the disc- get message
Check and replace the laser pickup unit. It is faulty [Weak]. If you wish to get some details; visit the site linked here. Pull up older posts.
Dec 28, 2017 | Panasonic PV-DF2703 Triple Play 27 in....
DVD PLAYER Locker
press the stop key on the television and the on/off button on the remote at the same time.
Dec 26, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
DVD doesn't play any disk anymore. Displays a message: this can't of disc can't be played ... I tried several different types of disks.
Same here! It would say something along the lines of "this type of disc cannot be played. please insert a different disc." it's the appropriate dvd region, i've tried all types of dvds, and it still won't work. the vhs and cd still works, it's just the dvd player that won't.
Mar 30, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Unable to open my DVD player
i have same problem with vcr , all mecahnism ok but dvd ok but vcr does not work all mechanism ok beccause i check manul its and are ok let me know if you knw somethins , in your case chech manual it open the dvd internal and check for work manual . wilfred
May 27, 2007 | Panasonic PV-DR2714 27 in. TV/VCR/DVR...
Panasonic PV-DM2093 Triple Play 20 in. TV/VCR/DVD Combo Logo
171 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
