Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
Posted by man_haiter07 on
D. Floyd Kolb
  • Frigidaire Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 26, 2010
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: frigidaire Gallery washing machine fills up but
machine has a transmission and clutches and they will go bad.
Posted on Aug 24, 2009
Testimonial: "Put me in the right direction."
Mukesh Kumar
  • 3230 Answers
SOURCE: Front load washer won't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Good Luck!!!
Posted on May 06, 2009
Anonymous
  • 4 Answers
SOURCE: Front loader will not spin
Might be a burned (a few coils) motor - feel any burned paint smell?
Alternatively, a broken belt - you'd hear rthe motor spinning, though - or some sensor/wiring malfunction.
Posted on Jan 14, 2008
Anonymous
SOURCE: washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Posted on Apr 15, 2009
Anonymous
  • 1531 Answers
SOURCE: Frigidaire Gallery Series GLTF2940 front load
check the belt make sure it is still contected.
if that is good you may have a faulty door lock
Posted on Apr 10, 2010
1helpful
Frigidaire gallery washer smoking and not spinning
Sounds like you either have something in the pump or maybe the belt is slipping on the pulley.
Frigidaire washer repairs
it almost has to be the belt think the front comes off to check it out
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
417.39022890 Frigidaire Gallery Frontloader won't spin
Does it move at all in the spin cycle? If it does, try to open the door during the spin cycle and tell me if the door opens or stays locked.
Frigidaire gallery top load washer is leaking and will not wash big load
Hello msmm50 - Contact a professional so they can properly and accurately diagnose the unit for repairs. Sounds like you have a leak in the drain lines or the water valve.
Top Frigidaire Washing Machines Experts
Marvin
Marvin
David Shaub
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
