When you here a loud pop its usually the sustainer boards. Have you checked the fuses on the sustainer boards first to see if they are still good. There is a IC chip under the heatsink and when it gets extremely hot it gives. Also check you power supply board to make sure you don't see any swollen capacitors, leaky or bulged out from the top. Let me know if that helps at all.
hello ahmosea i have a 42 vizio plasma an the same thing happen. i herd a pop then the screen went blck,it has since came back on but picture is still very dark an as it heats up it almost looks as if the black melts away a little bit an then the image kinda comes in(hope that makes sense). checked the y an z sus bord's an the fuses an capactrs seem ok. i looked at the pwer suppy bord an thers a fuse on that bord that has sum yellowish stuff on the fuse. is that a burnt fuse???? an can that be my problem?? thank you for any input you may have.
