Power light comes on and clicking is heard but no picture or sound on 42" Samsung TV. main power supply board replaced capacitors look good fuses all checked and none appear blown...
Unfortunately plasma tvs are a lot more complex to service, instead of 2 or 3 boards there are a half dozen at least. I would guess when the main PS board went out it took some other boards with it. I don't have a manual for your set but I would look at the power supply sub boards, there generally are 2 of them, or on some models that is parts of the other boards. Generally there is a legend to see what voltages are supposed to be present at what places, samsung is good about making the test points on the boards. Also there are fuses on most the other boards and its possible one of those has blow, it won't be a typical fuse like your used to seeing, some are a small green component and some are white mini fuses...Good luck!
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
This problems it the causes by the power supply board have dead parts call capacitors.That the board,where the power a/c cord plug into it.U have tools like a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?U know basic electronic and can do basic soldering?Yes,check the power supply board for dying and dead capacitors,these capacitors are alway bulges up or puffing up on it tops.Replaced these dying and dead capacitors parts,will get ur tv stop making clicking sounds and the tv power will be stable again,tv will work.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623) SM 3A 125v-fuse----(242208600657) 500 MA-fuse-----(242208611092)
what the full model number of your tv? the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!) Samsung settlement warrants older TVs with faulty capacitors
