Question about LaCie F.A. Porsche (301177) Hard Drive
Hard drive won't turn on. orange light rather than green/
    Brigadier General:
  • 10,406 Answers
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Posted on Oct 26, 2010
Monitor wont come on the power button light turns from green to orange and nothing on the screen
check your display card .. remove the memory ..clean the contacts and put it back.
Aug 30, 2014 | Compaq Computers & Internet
When I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
b>
Feb 12, 2013 | Apple iPod Shuffle Second Gen.1 GB MP3...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Charging
You don't need to charge is. The light turns green when in use - either to read or write something on it.
Jun 05, 2010 | Aluratek AHDU350 USB 2.0 Hard Drive
HD will power up, green light comes on and then
I am having the same problem! I just want to retrive the information on the ehd
Dec 14, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
What are the blinking light error codes for
the interphase between the raw drive and the usb cable is faulty or blown up.
use the raw drive from the casing to power it directly to pc it would start working
Sep 19, 2009 | LaCie F.A. Porsche (301177) Hard Drive
When i turn my computer on the big button which is usually green doesnt work. there is a smaller light which is also usually green just below the big one which starts green as i turn it on and then it goes...
Make sure your cables are all firmly connected. Also check the power strip or surge protector. If all is connected well and the pc will still not turn on it looks like the problem is the power supply unit, which can be replaced for around $20. I hope this works :).
Aug 16, 2009 | Compaq PRESARIO SR1475CL AMD Athlon 64...
When the computer is plugged in it doesnt work. The datech fan doesnt work. The front of the computer displays an orange light instead of green. If I replace the fan will this correct the problem
Replacing the fan as far as I know should not cause a light change but instead the computer would get hot shutdown every time he got too warm the orange light usually signifies a hardware problem. If you have opened your computer before you might have accidentally disconnected the hard drive or one of the cables from the motherboard. If the hard drive is disconnected that usually will get an orange light or if a ram chip is missing or not in all the way does a computer beep when you turn it on
Jul 27, 2009 | Dell Dimension 3000 PC Desktop
Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
Apr 22, 2009 | Acer Aspire 5003WLMi Notebook
Lacie 500Gb Hard Drive Porsche design
Hallo,
my disk, when on, is not recognised by Windows while the light is flashing between yellow and orange fast (like a car's flash -faster-). please could anyone help me? - i need my data!
Thank you.
Aug 21, 2008 | LaCie 500GB FireWire-400 Porsche - 7.2K...
LaCie F.A. Porsche (301177) Hard Drive Logo
382 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
