Question about La Crosse Radio Controlled Atomic Clock
I have a radio controlled clock they told me it would automatically catch up the time from daylight saving , but it has not .the clock is a ls works and the radio controlled DCF mechanism is a quartz CH-899 CHOUCHIN
Posted by tony813 on
  • 1 more comment
  • Anonymous Mar 16, 2014
    Bought a nice clock at a yard sale , I didn't konow it was a Atomic clock till I looked on the back . what do i do to get i running
  • Anonymous Mar 31, 2014
    HOW TO RE-SET
  • Susan McManus
    Susan McManus Apr 20, 2014
    There is a toggle switch in the back for DST.
Anonymous
    New Friend:
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
Apr 21, 2016 | Sony ICF-C318 Dream Machine Alarm Clock...
Tip
Daylight Saving Time Changes for SmartSet Clock/Radios
Dear Emerson SmartSet® Clock/Clock Radio Owner:
Your Emerson SmartSet® Clock or Clock Radio includes Emerson’s patentedAuto Time Setting System that
automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and
after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and
alarm settings for up to 5 years, or even longer.
As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/
Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into
all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight
Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April
and ends on the last Sunday in October.
The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to
extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in
March and end on the first Sunday in November.
Of course this is a situation that is beyond the control of Emerson, or any other company that produces
devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA’s, and
many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to
make adjustments to the automatic DST software to agree with the new DST timing for 2007.
Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It
would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows:
1.) On the second Sunday in March you would have to set your clock to the next lower number time zone.
For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone
1 to move it ahead by one hour.
2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the
clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set
your clock back to Zone 02.
3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone.
4.) On the first Sunday in November you would again set your clock back to your correct time zone.
Instructions for changing the Time Zone setting are found in the Owner’s Manual.
We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
Printed in China
508-02
on Jun 13, 2009 | Emerson Smartset Clock Radio
How do I get my smart alarm clock to reset itself automatically since the goverment changed the daylight savings time? Or, if I buy a new one will it have the new time changes?
The Daylight Saving Time settings are not user controlled, so you cannot convert the changeovers to the new schedule - you can only change the time manually. Any new clock or clock radio with automatic settings will work on the new schedule.
Bill B
Apr 04, 2010 | Emerson Smartset Clock Radio
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Daylight saving time problem
Sorry it took so long to reply to your questions about the change for the new daylight saving standard. The following link will take you to the customer support page for Emerson Radio. This page contains the directions for making the all the proper changes to you Clock/Radios. You will need a pdf reader and writer to read the information and make a copy for your records. [http://www.emersonradio.com/owners/SmartSet%20Series/DST%20Information.pdf] Copy this link and paste it into the address bar of your web browser. I hope this information helps you solve you problem with new daylight saving changes to your Clock/Radio. Thank you for using FixYa and have a nice day!
Mar 09, 2008 | Emerson Smartset Clock Radio
There was a sheet of paper that came with my clock explaining how to adjust the daylight savings time settings, but I lost it.  Anyone have theirs?  All i know is it requires that you press an awkward combination of buttons simultaneously, but that's it.
Nov 06, 2007 | Zenith Z230S Clock Radio
Daylight saving time auto change over
call 18006954820 they will walk you through
Nov 02, 2007 | Timex T276B Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
La Crosse Radio Controlled Atomic Clock Logo
13,483 people viewed this question
Top La Crosse Home Experts
Lawrence Oravetz
Are you a La Crosse Home Expert? Answer questions, earn points and help others
