SOURCE: Instruction book required for High-Point microwave/convection
Here's a roundabout way to help you:
You can find a different High-Pointe RV microwave owner's manual here.
That manual should have contact info to help you get in touch with High-Pointe to get a new one, or it may be close enough to your model to work for you.
SOURCE: Just moved into a home with a Sharp
Yes, this is a common item. Any appliance store that handles the Sharp line will be able to order the racks for you, if they do not have them in stock.
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
We're
SOURCE: Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
SOURCE: Looking for a printable/downloadable owners manual
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's manual is available in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
