TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume
you
know the theory. I will show you the key strokes
For
1-Var statistics
Press [MODE][3:STAT] [1:1-VAR].
You are ready to
enter values in the X column.
Enter a number and press [=]. Cursor
jumps to second number to enter.
Keep entering numbers and pressing
[=] till all numbers are in. Press the [=] key after the
last one.
Press
[AC] key to clear the screen.
Press
[SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the
statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press
the
number corresponding to the statistical value you want, ex 1:n . The
variable appears on screen. Press [=] and it will be displayed.
To
display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x
press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x].
Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To
perform
2 variable statistics you press [MODE][3:STAT] and any of the
other regression options (except 1:1-Var). A two column template opens
where you enter the X and Y values. When finished entering data, press
[SHIFT][STAT][5:Var]. to access the different statistics. As I assumed
above, you should be able to
recognize what each variable means.
My name is adieh. Hav a great day.
Here are the tips on how to calculate standard deviation using a graphic calculator:
1. Turn on your graphing calculator, go to the stats/editor screen and enter your data set into list1. Once this is done, return to your home page by hitting the home button.
2. Push the catalog button and scroll through the applications until you find "stdDev(". Place the arrow next to it and press enter.
3.Type the word "list1" into the open parenthesis. After you have put that in, close the parenthesis so you calculator doesn't show an error message.
4. Press the enter button. The calculator has done the calculations and you now have the standard deviation of your data set.
Note:
Using 1-var stats in the stats/editor screen will also give you the standard deviation. Using that function will also give you other information associated with your data set.
Hope it helps.
Thank you for using fixya.
